Question about Gateway Wireless-B Router (wbr-100)
When i am openling the web 192.168.1.1 the linksys basic setup is not showing
    Problem Solver:
  • 11 Answers
Check if your computers lan settings is set to DHCP mode so it could get a correct net address.
if its set to DHCP and still not connecting....reset your linksys router so your computer can get a new net address.
Posted on Feb 04, 2010
How do i log in for the first time
Basic step for login Linksys Router :
  • remove the router and modem power plug.
  • connect your router with modem.
  • power up router and modem.
  • open the Web Browser - 192.168.1.1
  • username- admin or blank and password- admin.
that's all for login
if looking for more help http://support.linksys.com/en-apac/support/linksys and Router Support for setting up your router setting.
May 19, 2014 | Computers & Internet
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Linksys router WAG200G not automatically connecting to ISP
try to access the Graphical Interface of your router.
1. Open your browser then type in on the address bar 192.168.1.1 then press Enter.
2. Type in the username and the password.
3. Check on the basic setup under basic setup there show be a dot on enable under Auto detect.
4. After putting a DOT click on save settings.
Hope this would help. Thanks.
May 30, 2011 | Linksys WAG200G Router
How do i setup my wireless linksys model wcg200?
The wireless settings that you need to take note of are:
a. SSID - this is the name of your wireless network
b. SSID Broadcast - an indication if your SSID is showing on the list of networks available
c. Wireless Security - serves as the password for your wireless network
To check the wireless settings on the Linksys router, follow the steps below.
Checking the Wireless Settings on the Linksys Router
Step 1:
Access the router's web-based setup page. For instructions, click here. If you are using a Mac computer to access the web-based setup page, click here.
Step 2:
When the router's web-based setup page appears, click Wireless.
4678-009.png Step 3:
Look for Wireless Network Name (SSID). If it's still set to "linksys", change it to something unique then click 6-4680.jpg NOTE: Take note if SSID Broadcast is Enabled or Disabled. If it is Enabled, it means your SSID will show among the list of wireless networks available when any wireless device will search for a network to connect to. If it is Disabled, it will not be visible.
Step 4:
Click the Wireless Security subtab and take note of the current Security Mode.
If Security Mode is set to WEP:
4678-007.png If Security Mode is set to WPA:
4678-013.png You can change your WPA shared key if you want to personalize it. It should be a minimum of eight and a maximum of 63 characters long.
Step 5:
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | Linksys WCG200 Router
Setting up wireless password
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
How do I disable DHCP server of the wrt160n so my d-link router is the main router?
you need to open a browser and enter the numbers 192.168.0.1 in the address bar. it will ask for a user name and password. the default user name and password is "admin". if you have entered a different password while setting up the wireless connectivity, please use that password. once you entered the credentials, you can disable the DHCP server in the setup page of the linksys router. i have attached a screen shot for your reference. if you have any difficulties in doing this process, please reply to this message. hope it helps you. glvenu.jpg
Nov 04, 2010 | Linksys WRT160N Wireless Router
I'm having problems not only with registration but also connecting the router.
Kindly follow the below steps to setup your router, this will help
LinkSys Router Setup Physical Setup of a LinkSys Router Each model of LinkSys router will differ slightly, but the general design is similar across all models. Therefore, the setup is similar across all models.
  1. Attach the antennas to the router (if your LinkSys router support wireless)d
  2. Plug the Ethernet cable from your broadband Internet provider into the port labeled "Internet"
  3. Plug another Ethernet cable into one of the available ports
  4. Plug the other end of that same cable into an Ethernet port on your PC
LinkSys Router Configuration LinkSys routers now ship with a Setup Wizard which is intended to simplfy basic configuration tasks.
We do not recommend the LinkSys Setup Wizard for two reasons:
  1. The Setup Wizard is not significantly easier that the regular configuration menus
  2. If you use the Setup Wizard, you will end up learning two interfaces for your LikSys router instead of just one
Instead, we recommend simply starting your web browser and jumping into the configuration.
Once your web browser is open, go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password.
Logging in to a LinkSys Router
The username is either blank or "admin" and the default password is "admin".
Once you are past the login screen, you are able to access (and change) a plethora of configuration options for your router.
Don't be worried by the enormous number and variety of options, your LinkSys router ships with default settings that enable it to work right out of the box in most environments.
From here the configuration options that you choose are largely up to your own personal preference.
If this is a wireless router, we recommend that you consider setting an SSID to identify the router as your own and configuring WEP to encrypt your wireless traffic.
Let me know if this will help
Regards
I can provide you more on Linksys router as i work on them :)
All the best
Nov 29, 2009 | Linksys Wireless-G Broadband Router
How do I set up my Linksys router?
LinkSys Router Setup Video Tutorials Learn how to set up your Linksys Router.
Thomas installs a Linksys router to demonstrate what ease-of-use means.
I really hope this information is helpfull.
Aug 12, 2008 | Computers & Internet
I don't no how to hook up my Adsl Gateway
See if maybe this will help. You didn't say what type of router(wired or wireless). Yhis should give you some idea. Hope this helps. Thanks
Feb 18, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Gateway Wireless-B Router (wbr-100) Logo
96 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
