Question about Acer TravelMate C110 Tablet PC
Where is cmos battery in c110 tablet located as i have to rplace the battery.
  • 6 Answers
Below in-between Speaker & Touchpad.
Posted on Apr 07, 2010
I am looking for travelmate c110 keynoard to replace the current keyboard.
http://www.cdsparts.com/p-37-new-acer-travelmate-c110-series-keyboard-kbt2707001.aspx
This is a place to buy a new one. Let me know if you need any more help. Hope this helps.
Mar 07, 2011 | Acer TravelMate C110 Tablet PC
Where is internet switch on a acer travelmate c110 tablet pc
On the acer travel mate only some models came with wireless and others did not. If yours has wireless the switch should be located right on the front of the computer. I hope this helps
Jun 23, 2010 | Acer TravelMate C110 Tablet PC
How do i change the cmos battery in a travelmate c110. The time and date and bios settings keep changing. Figure it needs a cmos battery. thanks
The cmos battery is exactly located beneath in between the touchpad and speaker, it's a meticulous job, you could see a twin cable leading through the keyboard area. After removing the keyboard, cut the battery wires at the edge of the old battery and replace the new sealed pack by soldering its wires to the same connection. Be cautioned not to break off the slim edges of the keyboard sides by attempting to reach the battery while lifting up top silver panel from the front near the Infrared.
Nov 12, 2009 | Acer TravelMate C110 Tablet PC
Hibernation
Remove the battery and unplug the laptop. Hold the power button down for 10 seconds. Plug it back in, pop in the battery, turn it back on.  Let me know if that works.
Feb 02, 2009 | Acer TravelMate C110 Tablet PC
Can`t find the cmos battery ML2032 RECHARGABLE 3V in the shop
Hi I am Vortash this battery is usually accessable from under the keyboard on most computers.. however some have their own access door under the computer , and I have seen a couple behind the Ram module under neath them in fact .... hope this helps Regards Vortash
Dec 18, 2008 | Acer TravelMate C110 Tablet PC
Acer c110/ c112 CMOS Battery
Here is how I replaced it.
CMOS battery is under computer battery. Take computer battery out, open the cover under it you will see the CMOS battery is in black plastive cover. Cut a line through the cover until you can reveal soldering point. Use a soldering gun to remove the old one and solder the new one in. Wrap up the cover. You can buy sodering gun for 14 quit. I would not choose the risk to break the computer plus hours to disassemble & reassemble the computer. Note: Time is money! The time I spent is 3 minutes.
Sep 02, 2008 | Acer TravelMate C110 Tablet PC
Cmos battery for C110 TCI
The CMOS Battery is behinf the main battery behind a platic shield. The shield is relitivly fragile and glued around the edges. Care should be used removing it to prevent ripping. The battery itself is 3" flat pack glued to the case. Mine was wrapped in a black heat shrink with two wires exiting.
The connector is under the keyboard. You will need to remove the 6 scres from the bottom of the case to release and remove the keyboard. The keyboard ribbon cable is attached through a ZIF socket. Be sure and release the cable before removimng the keyboard. Youll have to trace the CMOS battery leads to determine the correct connector.
I found a Maxell ML2032 rechargable battery. Unfotunatly all the 3" flat pack batteries I have found are LITHIUM ION and not rechargeable. If I find a replacement I will post the information.
Apr 27, 2008 | Acer TravelMate C110 Tablet PC
C110 tablet
This is likely your CMOS battery dying on you and resetting your computer's date. Hitting F2 I belive it is will allow you to access your bios and on the second page you can see your date. It will likely be Jan 1st, 1988. Use your number keys to adjust the date and use your tab key to move between month, day, year, ect.
This is a temporary fix however and you will have to do this often until you have your CMOS battery replaced. I have a Travelmate that has the same problem.
Nov 08, 2007 | Acer TravelMate C110 Tablet PC
Acer TravelMate C110 Tablet PC Logo
566 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
