Question about D-Link AirPlus DI-524 Wireless Router
DI-524 Wireless can I use wireless connection with DI-524 only in LAN segment (wihtout WAN connections), and use gateway on other router connected on LAN port.
Asas
Posted on Jul 30, 2008
    Scholar:
  • 60 Answers
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Posted on Feb 23, 2008
Unable to set , even type the password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 14, 2010 | D-Link AirPlus DI-524 Wireless Router
Di 524 through speedstream 5200: wireless connects but no browse
try re-installing the driver for your USB adapter or create a new wireless network name.
You could also try to download the latest driver for your USB adapter. uninstall the old driver before installing the latest driver for your USB adapter.
Jan 04, 2009 | D-Link AirPlus DI-524 Wireless Router
No wan light
If no wan light bypass the dlink router and check if ethernet cable connected to wan port is working. Once you are able to go online through modem connect cable to WAN if light does not go on log into oruter and clone mac address and save settings.If doesnt work powercycle router and turn modem on first then router next if doesnt work upload latest firmware.
Sep 05, 2008 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
How to connect wireless router to adsl router?
You're wanting to connect the directly connect the DI-514 to the ASDL modem to give you a wireless network, right? If so here's what you do:
Connect an ethernet line from the modem to the Internet/Wan port of your DI-514 and then you're set. I recommend you then follow the directions in the manual to setup wireless security.
If you're wanting to have your DI-514 wirelessly connect to the ASDL modem, then connect your PC to one of the LAN ports of the DI-514 and open the administrative web interface (usually located at http://192.168.0.1) and go to the wireless section and select "Wireless Client" and input the MAC of the ASDL modem's wireless interface (you can find this on the administration web interface of the ASDL modem) and you should be good to go.
Feb 10, 2008 | D-Link DI 514 Wireless Router (DI-514)
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
Aug 17, 2007 | D-Link AirPlus DI-524 Wireless Router
Suggest config of DI 524
Are you using a DHCP server for boths sites A & B, or just using static IP addresses for all the PC's ? What is your IP scheme ? Are you using this D Liers just to connect sitenk routers just to connect sites A & B? Sorry for all these questions, I am trying to picture your network before attempting a solution for your needs.
Jul 31, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
406 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
