Question about Yahoo Messenger
Cannot login cannot sign in in yahoo messenger!!
  • Yahoo Master
  • 2,932 Answers
Try each of these in turn - if successful (or not) please feed back information to help others.
1) Since Internet Explorer is a vital tool in Yahoo (even if you use another browser as default I would recommend installing the latest version and update any support software for IE by using an update checker
http://www.filehippo.com/updatechecker/
2) Start with a clean browser
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.
http://www.filehippo.com/download_ccleaner/
3) On the sign in page click 'Messenger' > Connection Preference
Toggle between 'Connect direct to the internet' and 'Proxy setting' make sure the information is correct in the lower 2 boxes
4) Check these settings in IE (even if you have another browser set as default)
a) Tools > Internet options > Connections > Lan settings > check 'Automatically detect settings - uncheck other options
b) Tools > work offline - make sure this is NOT checked and has a red X through it
5) Disable your firewall and do a trial sign in
6) Control Panel > Internet Options > Connections > Lan Settings-uncheck Proxy server and check automatically detect setting
7) Control Panel > Internet Options > Connections > dial-up and virtual private Network setting > select your default connection > setting > check automatically detect setting
Posted on Feb 05, 2010
Try the forgot password, even if you know the password, it will help you with all the details, and you might be able to reset the password.
Posted on Feb 04, 2010
4 Suggested Answers
weblord
  • 507 Answers
SOURCE: Problem signing into Yahoo Messenger.
uninstall yahoo messenger completely and download a fresh one, re install fully, if still has errors, contact ym http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html
Posted on Nov 20, 2008
  • 79 Answers
SOURCE: Login error 81003004 from Yahoo Messenger
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Posted on Jun 08, 2009
wbwTeam
  • 74 Answers
SOURCE: login messenger with out downloading messenger in system
One of the best sites which provide instant messaging capabilities is http://meebo.com
The site is able to emulate Yahoo Messenger quite well. It's not a perfect solution, but is one of the best you can get without installing Yahoo Messenger.
Best Regards, Traian
Posted on Mar 24, 2010
Last login of yahoo messenger
You can find the location or IP address of anyone signing into your account.
Click on "Hi, Xxxx" the the top left of this page and select "account info" and sign in.
Click on "View your recent sign-in activity".
Apr 13, 2014 | Yahoo Messenger
Hi i just created my yahoo mail account hoping that this account will help me to have my yahoo messenger but when i started to sign-in at yahoo messenger it denies my log-in info..how can i use my yahoo...
To login to your yahoo messanger, carefulluy login your yahoo user name and password to your yahoo messanger.
also if is not working go to mail.yahoo.com and login to confarm your account is still valid.
try it and get back to me.
Jul 08, 2011 | Yahoo Messenger
How to get account on yahoo messenger
. When you have completed the installation process, you should see a confirmation message in your browser window. Click "Sign up now" under "Get a Yahoo ID. "
If you closed the browser window that displayed the "Congratulations! You have successfully installed Yahoo Messenger", then you can go to http://messenger.yahoo.com and click the "Sign Up" link next to "New User" at the top of the page.
2. Complete the Yahoo Account form. A sample form is shown below.
While it's not required include an an alternate email address on the Sign Up form, it Yahoo login name/password, Yahoo will send you an email with the login name/password to the Yahoo email address that was created when you set up your messenger account. However, since the login and password for your Yahoo email account is the same as the login for your Yahoo Messenger account, you will not be able to retrieve the email. In this case you will be forced to create a new Yahoo account.
3. Write down the User ID and any other pertinent information from the confirmation screen. Keep this in a safe place as you will need the login name and password each time you use Yahoo messenger/Yahoo email.
Jun 29, 2011 | Facebook Apps
I cant run my multi messenger
Official Yahoo! Messenger only allow one login on one computer. If you want to sign in with multiple accounts, try KarooLark web messenger: http://karoolark.com/ . It support multiple login for Yahoo! messenger and others.
Jun 29, 2011 | Yahoo Messenger
How do i sign up for yahoo messenger
If you want to sign in to Yahoo messenger, plz download Yahoo messenger from Google & install it. After that you need to create an account in yahoo. After creating the account you can able to login to yahoo messenger...
Thanks & Regards
Anas K A
Apr 22, 2011 | Yahoo Messenger
Automatic login on star up
Sign in to your yahoo messenger - Click on the Messenger - Go to preference and follow the graphical representation 4e0ea0c.jpg Before you log in don't forget to select the REMEMBER MY ID & PASSWORD and SIGN IN AUTOMATICALLY.. Good luck.. do let me know if the u can't make this out...
Apr 29, 2010 | Yahoo Messenger
I can't sign in to my yahoo messenger, can someone
You open your yahoo messenger (don't sign in yet) and click on the 'help' (above login) and then click on 'Report a Problem to Yahoo!'. Just follow prompts/state your problem that you can't sign in. I did it everytime I can not log in to ym. Hope this helps.
Nov 07, 2009 | Yahoo Messenger
My yahoo messenger locked..
go to http://www.yahoo.com/r/m6 put your yahoo ID and password correctly...then click sign in , if the page asks again to login put ID, Password as well as captcha varification code correctly displeyed in image box. after login now try login with yahoo messenger....best of luck
Oct 21, 2009 | Yahoo Messenger
Jun 05, 2009 | Yahoo Messenger
Sign in problem in yahoo messenger
Vadalli,
I believe that your Yahoo.com login should be the same as your Yahoo Instant Messenger login info., so verify your Yahoo.com username and password and try them to login to YIM.
If not, when you're notified of the login error, there should be a link for forgotten Username and/or Passwords within the error notification if U.N or PW are the problem.
Good luck.
Mar 10, 2008 | Yahoo YHT-630 System
Yahoo Messenger Logo
102 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
