Question about IBM eServer xSeries 346
Ibm x346 single 2.4 intel xean processor
Hi
I am  newbe to ibm servers . i get eror code 199 processor mismatch system halted and the
 orange amber  light begin to glow.pleas help me to boot up. Thanks in Advance
  • greenice Mar 02, 2008
    Thanks for your Soluion.
    I swapped the processor with another similar machine . It works fine thanks for your suggestion
    Scholar:
  • 131 Answers
Hold down F & J keys when booting your server.
Posted on Feb 23, 2008
Nmi error
Chip-set or memory error that relates to parity or ECC (error correcting) Try singling out your system memory and see if you still get this error.
Feb 05, 2014 | IBM Xseries x346, 1 x xeon 3.6 ghz/1 mb,...
Planar fault IBM 3550 M3
Ok, That' s a motherboard issue. You would have to replace motherboard...
Workaround:
1: Set server in minimum configuration(single processor and two RAMs)
2: Remove any PCI cards added in server
3: Turn on server check for issue
If plannar fault appear, you have to replace motherboard..
Thanks
Feb 14, 2013 | IBM x3550 Server
I need scsii driver for IBM X346 for UBUNTU
Hello you can try to download the drivers from here:
http://www-947.ibm.com/support/entry/portal/sdd?key=5178881&osKey=null#5282380
Do you have the latest version of ubuntu if not download here:
http://www.ubuntu.com/download/server
Try the 32 bit version.
Try also the ubuntu forum:
http://ubuntuforums.org/forumdisplay.php?s=45713461a2219625389237c1c60ec045&f=130
Good luck
Oct 27, 2012 | IBM eServer xSeries 346
Ibm raid controller drivers for x series 346 server
I have a problem with x346 server i need raid drivers for windows server 2008 32 bit please if some one can help/
May 13, 2011 | IBM xSeries 346 Server
I have an IBM x346 eserver that has run well for years. The fans are now very load (whirling noise). I typically only hear this noise when the room temp is high, but this server is in a cool room with no...
It sound like the CPU fan or server case fan/s or power supply fan bearings are worn.
To determine which fan/s is faulty open the computer case and stop each fan from spinning, one at a time to determine the noisy fan. Once you have identified the noisy fan then replace that fan.
Feb 07, 2011 | IBM xSeries 346 Server
Intel cpu comparable to "Dual Core AMD Opteron 1212HE"
This is an AMD 2nd generation Opteron CPU, running at 2GHz. It is a single core device. So a comparison would be against Intel business CPU - the Xeon, again compare against a single core.
Apr 02, 2009 | AMD Opteron Dual-Core 1212 HE 2.0GHz...
Can I install Windows Server on IBM RS/6000 51A Server ?
No. The IBM has a RISC processor and Windows only supports Intel or AMD. It does support some versions of linux if you want a GUI interface. :-)
Regards,
Daryl
Jan 14, 2009 | IBM RS/6000 9.1GB DASD FEATURE
IBM server x346 has problem
The x346 server should have 2 SMPS in the server , Try connecting one power and test and then try the other , incase the smps has some problem such issues ivolve.
Dec 25, 2008 | IBM eServer xSeries 346
Windows 2008 server installation in IBM X346 server
http://www.soft32.com/Download/Free/Adaptec_AIC7902_HostRAID_driver/4-173525-1.html
Try this one
Dec 11, 2008 | Microsoft Windows Server Standard 2003 for...
IBM eServer xSeries 346 Logo
493 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
