Question about Yamaha RX-V750 Receiver
Pure direct button flashes and unit does not turn on
Reset factory settings of my Denon avr 2800
From Denon support:
To reboot, turn receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory default.
Sep 08, 2013 | Denon AVR-2800 Receiver
Reset factory settings on my devon avr 2800
From Denon support:
To reboot, turn the receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory settings.
Fl off red led flashes on display and i can't do nothing
When you first turn it on, press the "pure direct" button to turn pure direct off.
Feb 08, 2013 | Marantz UD5005 BluRay Player
The power light blinks red! it can't turn On!
"If your 8002/7002 goes into protective mode (red power light flashing at two times per second) the receiver will not operate until it is reset. First try the reset procedure on the bottom right corner of page 81 in the manual.
If that doesn't work, press and hold the following three buttons on the front panel until the unit resets:
Pure Direct
7.1 Ch input
Clear
This latter procedure is not in the manual and I can't fathom why, as it can save the inconvenience of a trip to the service center."
Feb 03, 2011 | Marantz SR8002 7.1 Channels Receiver
No sound other than from direct stereo or pure direct. Denon AVR 2808
You can try this reset precedure below, but it sounds like you may have a DSP board problem. This is a new model of Denon, it should still be under Denon's warranrty, it has a 2 year warranty. If this does not help, you need to take it in to be serviced. If it is not under warranty, you will not like the cost of the repair. A new DSP board usualy cost about $300 and then you must pay for the labor. It is not cheap. This reset procedure has been know to work some minor miracles, lets hope it works one for you.
1. Switch off the unit.
2. Hold the following STANDARD button and DSP SIMULATION
button, and switch on the unit.
3. Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
Note:��If step 3 does not work, start over from step 1.
�� All user settings will be lost and this factory setting
will be recovered when this initialization mode.
So make sure to memorize your setting for restoring
after the initialization.
Jul 12, 2008 | Audio Players & Recorders
I have the Denon AVR-3805 receiver and I can't get it to turn on. When I press the "on" button, it turns from red to green but nothing else lights up. Can you help me?
By now the person who asked this (eleanorr) has certainly solved her problem, but in case anyone else has this same question:
It *is* on, as the color change on the Power button indicator light shows. Most likely, the receiver is fine; it's just that your front-panel display is off!
1. Check the DIMMER mode by pusing the buttom on the front panel -- it may be set to OFF.
2. Push the PURE DIRECT button on the front panel (or remote control) -- it may be ON, which turns off almost all of the front-panel display. (Alternately, change the AV source, which turns Pure Direct OFF.)
Jun 24, 2008 | Denon Audio Players & Recorders
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
AVR 2807 shuts off at high volumes
You may have leaky Caps in the power supply or else dry joints on the amplifier section. Faulty speakers or overdriving of the system may result in the amp going into protection. Good Luck, Jus004
Jan 05, 2008 | Denon AVR-2807 Receiver
Lost surround sound
Maybe try a reboot. To reboot, turn receiver off by the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor1.gif has now been set back to factory. Enjoy this info is straight from Denon's Tech support. I had to do this on mine
Dec 26, 2007 | Denon AVR-2807 Receiver
How do you reboot the Denon AVR-2807 to factory settings
To reboot, turn receiver off by the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory. Enjoy this info is straight from Denon's Tech support. I had to do this on mine
Nov 25, 2007 | Denon AVR-2807 Receiver
Yamaha RX-V750 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
