Question about D-Link DIR-300 Wireless Router
I have D Link DIR-300 Router. It was working fine cuople of days back but now Its not letting me connect to the Internet. I am able to connect to internet if I bypass the router and directly connecting to modem. But when I am trying to connect wireless its not identifying Internet although I am able to connect to my wirless network. All the LEDs of the modem and the router remains on. Can someone suggest what could be the issue? I am using Windows Vista.
    Scholar:
  • 61 Answers
If a router was working flawlessly but suddenly stops working in the way you describe the most common issue are either connections that have become faulty [check wiring, swap out cables to see if any have gone bad] or settings/firmware have become corrupted.
If the latter bypass the router and go to the D-Link support site: http://www.dlink.com/support/
download the latest firmware for your router and follow the instructions provided for flashing the ROM to correct any corrupted code.
Remember to use the administrative functions through the browser access [usually accessed by typing this address: 192.168.0.1 into the browser for D-Link routers] to save all your settings to a file so you can replace them after flashing the routers ROM, for doing so will have reset those settings back to factory defaults.
Hope that helps.
Posted on Feb 04, 2010
Can't get internet to work with dir-615 router for more than a day or two at a time
If you have more than one device hooked up to the router, when the problem occurs try pinging another device. If you are able to then the router is working fine and most likely the modem is flaky and needs to be replaced. The modem supplies the internet connection, the router just applies NAT so that more than one device and use your public IP address. If this turns out to be the issue make sure you contact your ISP for any special instructions. For instances Comcast requires the MAC address located on the bottom or back of the modem in order for your connection to work, other ISP use proxy settings. Century Link has no requirements.
Jan 22, 2012 | D-Link DIR-615 Wireless Router
I cant get a internet connection with dlink dir-300 (cable or wireless), pls help, it's working when i tried with different router...
Welcome to FixYa! In regards to your problem there are possible options you could follow. 1. Check first if your computer is detecting the router. Go to your Network Connections and see if its detecting a connection with the D-Link router that you have. 2. I suggest go to this site that has a manual for setting up a D-Link DIR-300 Wireless Router.Check if you missed any of the process. Steps: Go to Google.com then type "cant get a internet Problem with the D-Link DIR-300 Wireless Router" and then look for DIR 300 Wireless Router Manual. There you will find all that you need in setting up your router. Hope this helps! Thank you for using FixYa!
Jul 04, 2011 | D-Link DIR-300 Wireless Router
Internet connection cutting out intermitently
1. check the current firmware updates
2. verify no other devices next the the router interfering with the signal i.e. cell phones, cordless phone, microwaves, TV sets.
3. check your router or cable modem for connection during time the wireless is dropping connectivity.
Apr 25, 2010 | D-Link DIR-615 Router
We have 2 laptops going through this router and
First you need to verify that what kind of Internet connection you have from the satellite and what you need to do on the router so that it can communicate with the modem like MAC address cloning or changing the LAN IP Address. On the basis of that we will need to reconfigure the router back as it might happen due to a power outage or small network glitch the router might have lost the settings stored on it.
Mar 17, 2010 | D-Link DIR-300 Wireless Router
D-link dir-300
Ensure that the router firewall is not blocking the http port 80.
Have you configured the router to open your utorrent port?
Have you set up specific strict rules?
Mar 05, 2010 | D-Link DIR-300 Wireless Router
My dir 300 is working fine but it disconnects from the internet
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 09, 2010 | D-Link DIR-300 Wireless Router
D-Link DIR-300 Router not working properly
Try to configure your router again, maybe that will solve your problem.
Jun 24, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I have a dir 300 router that when i try to hook it up it i cant
 Let me clarify this  your internet works when your PC is hooked up directly to the modem....
When you connect the router between the pc and the modem the internet does not work....
This sounds like the configuration settings inside the router need to be setup or adjusted.
Go to the web browser and type in 192.168.0.1 and for the username type admin and then leave the password blank hit enter and it should sign you into the router. Follow the setup wizard and everything should work just fine.
Hope it Helps!
Apr 12, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D-Link DIR-300 Wireless Router Logo
415 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
