Question about Cell Phones
NOT GETTING SWITCH ON
I HAVE CHANGED POWER SIM OFF POSITION TO ON,IT HAS TURN OFF IN 3SECONDS ITS NOT GETTING POWER ON
  • 3 Answers
Try again for that ,remove its battery & fix it again,god would help u
Posted on Feb 04, 2010
Head lights and brake lights not working
check power wire which runs to the brakelight with a test light, get someone to apply the brake on and off and see if there is power getting back to that point, if no power check the switch on the brake pedal to see if power is getting to that point.
also check the earth on the bulbs because they wont work if there is no earth
Jun 09, 2010 | 1987 Volvo 240
1990 fleetwood starting prob.turn key nothing i can hear fuel pump the relays click i can jump starter. but nothing changed starter it was on its way out checked all fuses cheked all fuse links cheked key...
I would check the ignition switch. With a test light, check the small wire going to the solenoid for power when someone turns the key to the starting position. If you aren't getting power to that terminal on the starter, the ignition switch is not sending power to the solenoid.
Apr 26, 2010 | 1990 Cadillac Fleetwood
I have changed the starter solinoid and now i dont
Make sure the starter relay is working properly. Check to see if you are getting power at the relay + cable. Then check to see if you are getting power from the relay to the starter, you may have to turn on the ignition or get someone to turn the switch over in start position. If you're getting power here, then your problem is elsewhere. Are you getting the car to start or just no electrical such as lights and etc?
Apr 19, 2010 | 1990 Ford F150
Has accesory power but ignition does nothing when held in start position.all battery conections are good,changed neutral safety switch and ignition switch,changed relay but still no luck!!
Not to be asking or saying dumb things but have you checked to see if your starter is even getting power. I't constantly gets power and a signal wire engages it to start because if it is than your starter is bad, if not than start trouble shooting from there up.
Feb 01, 2010 | 1995 Dodge Dakota
When i start the car i hear it trying to crank over but its not firing up i have changed the fuel filter and the power pack...nothing worked what do i do
Are you getting fuel to the engine. The fuel pump may be defective, since you have changed these items. A crankshaft position sensor will cause it not to fire up either. I had this happen on a jeep grand. So fin out if you're getting gas to the engine. then that will give you a better idea. Get someone to help, open the gas cap, put you ear close to the opening and have someone turn the switch on ( not starting engine) and listen for a pump to turn on. It may be a very faint sound. Try it a few times to be sure you hearing or not hearing it kicking on. It should turn on when the switch is in the on position.
Dec 28, 2009 | 1997 Mercury Sable
Monitor goes dead after after switch on after 3seconds
CCFL backlight may be busted.. also ccfl inverter may need repair or replacement too..
Mar 09, 2009 | GNR 19M1 19" LCD Monitor
Brake lights wont turn on.1994 gmc sierra.
This may sound too simple, but first verify that you are getting voltage to the light socket. Use meter on d.c. If you are getting voltage, and your bulb is good, it could be a bad ground. Don't overlook the brake light system goes through the directional signal in the steering column.
Jan 19, 2009 | 1991 GMC Sierra
CHINA MOBILE N92
Hi
You can reformat your unit.. just follow this instructions. just off the fone then, press together the key no. 3 Astiris and phone in.. press in sustained position then turn on the power switch then you can see your fone is starting to refurmat...
Jan 07, 2008 | Nokia N70 Cellular Phone
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
