Question about Kitchen Appliances - Others
How do you remove and replace an R7s halogen light bulb from its housing.? It looks like it shoul just push in at one end and release at the other, but does not seem to move far enough. Don't want to break the bulb (78mm, 100w, halogen tube).
Usually one side of the housing is fix, the other can be moved about 3-7mm. The whole ceramic body holding one sight of the bulb:
However different manufacture may have different designs, but this one is pretty common.
Posted on Oct 19, 2010
I have had a ledu 15" halogen desk lamp for many years and do not have an instruction manual. How do I remove/replace the halogen bulb? I cannot get it out of the housing.
One of the ends is a spring. Push it towards one or the other end and it should move. Don't touch the new one with your fingers. Oil on hands will shorten the life of the replacement lamp
Dec 11, 2014 | Cars & Trucks
How to change a light on a 2001 chev cavalier
remove upper air intake splash shield.remove the headlight housing retaining bolts and pull the housing assembly out to access the bulbs.rotate bulb holder counterclockwise to remove bulbs.WARNING YOU NEED TO WEAR CLEAN GLOVE TO REPLACE HEADLIGHT BULBS BECAUSE THEY ARE HALOGEN BULBS. IF YOU TOUCH HALOGEN BULBS WITH BARE HANDS. OILS FROM SKIN WILL CAUSE HALOGEN BULBS TO OVERHEAT BLOW OUT SO WEAR CLEAN DRY GLOVES.
Oct 26, 2012 | Cars & Trucks
How can the small halogen bulb be removed from the spotlight fixture? It is a small bulb, possibly mr8. I tried push and twist counterclockwise and a small suction cup with a straight pull. thank you.
if you have the replacement lamp, look at the end that goes into the base, it it has flat tangs, you need to push in as you turn it counter clock wise, if it has pins you just need to pull on it it should come out
Sep 18, 2011 | Hikari MR 8 12V 10W Lamp Bulb Replacement
NEED to change daytime running lights
YOU NEED TO RAISE THE HOOD,YOU HAVE TO REMOVE HEADLIGHT HOUSING BY TWISTING THE HEADLIGHT HOUSING MOUNTING RODS OUT OF THEIR CLIPS AND PULL UP THEM STRAIGHT UP TO DISENGAGE THE HOUSING FROM VECHICLE. WITH HEADLIGHT HOUSING OUT VECHICLE REMOVE LIGHT BULBS, YOU NEED TO WEAR CLEAR PAIR OF LATEX GLOVES WHEN HANDLING NEW HEADLIGHT BULBS BECAUSE HEADLIGHT BULBS ARE HALOGEN BULBS OILS FROM FINGERS OR HANDS CAN CAUSE HALOGEN BULBS OVERHEAT AND BLOW OUT.HALOGEN BULBS VERY EXPENSIVE THEY COST FROM $10.00 UP TO $20.00 OR MORE SO WHERE CLEAN GLOVES WHEN HANDLING BULBS.
Aug 03, 2011 | 2007 Chevrolet Suburban Three-Quarter-Ton...
My GE oven isn't lighting but the electrics work...What should I do? Please help
Bulb required: Manufactured by Aglaia for GE, 130V 35W Halogen bulb
There is a grille above the door and clock/cooking controls that extends the width of the unit. You need to remove this to get to the light receptacle. With the power to the unit off (unplug if you have access to it), get on a chair with a Phillips head screwdriver. Look down from the top and you will see two screws about 6" in from the ends. If you don't see the screws, open the cabinet doors above the unit (mine were blocking the screw heads). Remove the screws and set aside. Pull girlle towards you at the top being careful not to break the tabs at the position where the screws you just removed are located. After the tabs are out the grille should lift up (there are three hook-tabs along the bottom). Set it aside. Over toward the right you will see a smaller vertical grille. Just to the left of this there is a void with a Phillips head screw facing you. Remove the screw from the receptacle tab. Lift up the receptacle tab on the right. When the receptacle is clear on the right, move the receptacle to the right to release it from the tabs on the left. Lift the receptacle up until it clears the housing it just came from. Pull it gently toward you, rotate it bottom-toward you, and you will see the bulb to be replaced. My bulb was lightly held in using white silicone and removed easily by pulling it in the direction it was pointing. A word of caution about Halogen bulbs: When handling new bulbs be careful not to get any grease on them and handle them with clean cotton gloves or a clean t-shirt. Grease and oils from even clean hands will cause the bulb to burn out quickly. Replace the receptacle being careful to make sure the electrical wires are not pinched by the receptacle housing. Replace the screw; replace the grille; return power to the unit. You're done!
Lamp Halogen ranging in price from $8.10 to $10.71.
Jan 05, 2011 | GE Profile JTP18 Electric Single Oven
How to change a front turn light in a 1996 taurus.
Lamps, Parking Front Lamp-Lamp Assembly, Taurus
Removal and Installation
  1. Remove Headlamp (13008) as outlined.
Headlamp Assembly
  1. ani_caut.gif WARNING: THE REPLACEABLE HALOGEN HEADLAMP BULB CONTAINS GAS UNDER PRESSURE. THE HALOGEN HEADLAMP BULB MAY SHATTER IF THE GLASS ENVELOPE IS SCRATCHED OR THE HALOGEN HEADLAMP BULB IS DROPPED. HANDLE HALOGEN HEADLAMP BULB CAREFULLY. GRASP HALOGEN HEADLAMP BULB ONLY BY ITS PLASTIC BASE. AVOID TOUCHING GLASS ENVELOPE. KEEP HALOGEN HEADLAMP BULB OUT OF REACH OF CHILDREN.
    Position headlamp switch (11654) and headlamp time delay switch (13736) in the OFF position.
  1. Remove two bolts retaining headlamp (13008) to upper support assembly and loosen pinch bolt. Remove headlamp assembly from vehicle.
  1. Remove park lamp bulb and socket (Sable only) and headlamp bulb and socket from Headlamp Assembly as outlined.
    Headlamp Assembly (Taurus Shown, Sable Similar)
  1. Turn lamp socket and wiring (13410) assembly 1/2 turn counterclockwise and remove from parking lamp (13200) housing.
  1. Remove screw from park/turn signal housing.
  1. Using 1/4 inch drive socket extension and swivel, insert tool through two access holes in upper radiator support. Remove screws from park/turn signal housing.
  1. Remove parking lamp from vehicle.
  1. To install, reverse Removal procedure.
Nov 19, 2010 | Ford Taurus Cars & Trucks
How to replace driving light on 2002 nissan altima
FIRST OF ALL WEAR CLEAN GLOVES BECAUSE YOU HANDLING HALOGEN BULBS IF OILS FROM YOR HANDS GET ON BULB IT WILL BLOW THEM.TO GET TO BULBS YOU HAVE TO REMOVE HEADLIGHT HOUSING YOU HAVE TO REMOVE 2 TOP BOLTS SECURING HEADLIGHT HOUSING TO THE RADIATOR SUPPORT THEN YOU HAVE TO REMOVE RETAINING NUTS SECURING THE INNER END OF THE HEADLIGHT HOUSING FROM BEHIND THE RADIATOR SUPPORT.YOU NEED A MANUAL TO SEE WHERE YOUR HEADLIGHT SECURING BOLTS LOCATED.
Aug 30, 2010 | 2002 Nissan Altima
Replace front head light bulb on drivers side 2005 beetle
The headlight is actually a bulb inserted into a light module. You can remove the plastic light module by releasing the tension spring on the rear of the headliht housing inside your hood. Once the tension spring is released pull the plastic light module from the fender socket by gently pulling on the edges of the headlight. The module should pull out with some minor difficulty. Remove the bad bulb from the rear of the plastic bubble, and replace it with a new halogen bulb. Replace the module into the fender socket and reclip the tension spring(s). Not all that difficult of a job once you know how its accomplished.
Aug 19, 2009 | 2005 Volkswagen New Beetle
Change low beam
Headlamp Removal & Installation Bulb Replacement To Remove:
CAUTION
Halogen bulbs contain pressurized gas. Mishandling a bulb may result in the bulb shattering into flying glass fragments.
CAUTION
Make sure to wear eye protection when handling a halogen bulb.
CAUTION
Do not touch the glass of a halogen bulb, only handle the bulb by the base.
CAUTION
Do not allow a halogen bulb to come into contact with dirt or moisture.
CAUTION
Make sure to dispose of a used halogen bulb properly.
CAUTION
Do not allow children to handle halogen bulbs.
  1. Turn the lamp switch to the off position.
  2. Make sure the bulb is cool before changing.
  3. Remove the headlamp assembly from the headlamp panel.
  4. Remove the rear access cover from the headlamp assembly.
  5. Disconnect the headlamp connector.
  6. Remove the bulb from the headlamp assembly by rotating the bulb and socket counterclockwise.
To Install:
  1. Connect the headlamp connector.
  2. Install the bulb into the headlamp assembly by rotating the bulb and socket clockwise.
  3. Install the rear access cover onto the headlamp assembly.
  4. Install the headlamp assembly into the headlamp panel.
Jul 16, 2009 | 2004 Chevrolet TrailBlazer
Replace tail light bulb
open hatch, look for two screws, remove , push tail light gently back and forth to release from clips pull light assembly out , twist bulb socket to remove from housing, replace bulb.
Aug 20, 2008 | 2005 Kia Sportage
Kitchen Appliances - Others Logo
2,828 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
