Question about Philips SA5125/37 MP3 Player
Not read by computer
My philips 1gb gogear is not read by any computer at all....i tried using other usb cables...but still it dint...there seems to be a problem with the player...what should i do?
  • messa Feb 21, 2008
    but the software says no device is connected at all ....
  • 476 Answers
Install and run the Philips Device Manager software from the product CD.
Select the repair/restore option and follow the on-screen prompts.
Posted on Feb 20, 2008
  • David Simpson Feb 22, 2008
    The repair option tells you to press a key whilst connecting. This puts it into repair mode. Not sure which key. It should be in the manual.
My Philips Gogear is not recognised by my PC so I cannot download or upload music
Use the USB port at the back of your computer.
Set to MSC mode of your player. Select Settings -> PC connection preference.
Try to avoid using a USB hub. Try to avoid using a USB extension cable.
Oct 23, 2011 | Audio Players & Recorders
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
I want to get music on my mp3 player
After you sync your music collection to a Philips GoGear MP3 player with Windows Media Player, your favorite tunes will always be with you. Backing up your music collection on an MP3 player requires only a USB cable and a computer. Follow these steps to find out how easy it is.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderately Easy Instructions Things You'll Need:
  • Philips GoGear MP3 player
  • Computer
  1. Plug in the Philips GoGear to your computer. Use a USB cable to make the connection so you can begin synchronizing your music collection.
  2. Start Windows Media Player. Depending on how your computer is set up, this program may start automatically when you make the connection with the MP3 player.
  3. Find the Sync tab in the media player window. Click on this tab and open the Sync screen. The Sync screen has two panes. The left pane is for the music collection on your computer; the right pane is for the Philips GoGear.
  4. Choose the songs from your collection that you want to add to the GoGear's memory. Check the boxes that are presented by each song title.
  5. Click the "Start Sync" button. The files from your computer are being copied onto your GoGear MP3 player.
  6. Wait for the sync to complete. You can monitor the progress in the "Windows Media Player" window.
  7. Close the media player program. Unplug your Philips GoGear from the computer.
Hope this was helpful? Please comment for more information and thank you for using fixya
Jan 24, 2011 | Philips GOGEAR SA6045 MP3 Player
How to add songs to Philips SA2310 GoGear Mp3 Player 1GB MP3 Player from pc. does it needs any software??? where can i get that software?????
U DO NOT REQUIRE ANY SOFTWARE TO ADD SONGS TO UR PHILLIPS MP3 PLAYER. JUST USE UR USB CABLE TO CONNECT WITH THE PC. THEN U SEE ONE DRIVE NAMED REMOVABLE DRIVE COMES IN MY COMPUTER. JUST DOUBLE CLICK ON IT AND ADD MP3 SONGS AND THE SONGS ARE ADDED TO MP3 PLAYER. ENJOY THE SONGS IN PHILIPS MP3 PLAYER. GREAT SOUND.....
Sep 15, 2009 | Philips SA2310 GoGear Mp3 Player
Doesn't show up when i plug it in to my laptop
To download music or photos on to your Philips GoGear, you need to use a computer that has Windows Media Player and Device Manager already installed. Once these are installed, the steps to sync your Philips GoGear Jukebox using Windows Media Player are fairly easy to follow. Follow these steps to sync your Philips GoGear.
Connect your Philips GoGear to the computer with the USB cable. The USB connector on the GoGear is on the top, and will be on the front or back of your computer. You will see a USB connection icon as soon as the GoGear is connected to the computer.
1.Start Windows Media Player from the Start Menu or from the desktop. To transfer files to your GoGear from your computer, click Copy to CD or Device (with WMP 9) or the Sync tab (with WMP 10). 2.Find the Items to Copy pane. In the drop-down list, click the category or playlist that you want to copy to your GoGear. Make sure that items that you do not want to copy are unchecked. 3.Locate the Items on Device pane. In the drop-down list, click GoGear. When you have selected the items that you want to sync, click the Copy (with WMP 9) or Start Sync (with WMP 10) button.
Apr 25, 2009 | Audio Players & Recorders
Installation for philips gogear using apple macintosh
Can't. But, you can simply plug in the gogear into a mac USB port and manually drag music into the MUSIC folder. Files must go into that folder for player to recognize them.
Other than that, software only available for PC.
Apr 08, 2009 | Philips GoGear Flash MP3 Player
Need GoGear 1 GB MP3 player instructions
The manual is available from Philips website. I can't give you an exact link, because there are dozens of 1GB GoGear's.
Feb 19, 2009 | Philips Sport Personal CD/MP3 Player
Delete songs
If it is anything like my MP3 player, you would hook up the USB cable to your computer and it will get a letter assigned in My Computer. When I open that letter, all my songs are listed and I can add and delete.
Feb 07, 2009 | Philips Audio Players & Recorders
Problem of player
  • Try to connect the player to the USB port at the back of your PC if you connect the player to the USB port in front of your PC.
  • If a USB cable is needed to connect the player to your PC, use another USB cable and avoid the USB cable that is too long.
  • Uninstall the player and USB drivers from your PC and re-install them.
  • Nov 11, 2008 | Philips SA5125/37 MP3 Player
    Philips SA5125/37 MP3 Player Logo
    53 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
