Question about Hotpoint Dryers
Takes twice as long to dry clothes
Hotpoint ultima condenser dryer TC71 no longer heats up although the drum is still spinning Takes twice as long to dry clothes
    Problem Solver:
  • 5 Answers
Hotpoint ultima tcd980 condenser tumble dryer not drying properly
this sounds like one or two of your stats (tod) for short have gone if you need more help get back ok
Oct 22, 2012 | Washing Machines
How do you dry on this machine? if you dry on the green, does it completely dry?
The automatic preheat and drying cycle kicks in as the final wash spin is under- way. The system employs a condenser dryer in which the hot air used to dry the clothes is channeled into a drum, instead of being released into the great outdoors via a dry vent hose. Cold water is drawn into the drum at the same time. The two mix, and the result is a condensing process.
The chlothes should be dry. there may be a damp feeling to them but otherwise dry. If your machine is not drying then the element could be going bad, or a thermal cutoff. those would be the easyiest fixes.
The BIG drawback is drying. It takes about 90 minutes to dry a load, and the clothes come out very wrinkled. Because the drum is so small, the clothes don't 'toss' in heated air and don't fluff at all. Clothes also come out stiffer than a regular dryer.
Jan 06, 2011 | Equator EZ 1500 Front Load Washer / Dryer
Dryer won't get hot enough to dry clothes
mAKE SURE THE VENTING SYSTEM IS COMPLETELY CLEANED OUT. a MOISTER SENSOR DETECTS ANY BUILD UP OF LINT CAUSING TO KEEP THE HEAT IN CHECK WHICH TAKES LONGER FOR THE CLOTHES TO DRY
Jun 13, 2010 | Hotpoint NBXR463EBWW Electric Dryer
It takes longer to dry your clothes you have to restart the drye
first clean the pip from the unit to the outsde vent.
then inside your unit there are 2 felts that need to be cahnge, over time they go bad and the heat run out the drum and you can feel the hood is hot but it still not to good . it will save you electric bill when you fix it. :)
Dec 31, 2009 | Whirlpool LER4634J Electric Dryer
Hotpoint ultima condenser dryer TC71 is running cold
Thermostats rarely go. You could have a bad heater or even a voltage problem. Even if the dryer runs, the voltage can still be wrong, it only needs 110 volts to start the motor but must have 220 to have heat.
Apr 06, 2009 | Dryers
Drum wont move
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima TDL60P Tumble Dryer
u have some wires off
Jan 31, 2008 | Dryers
Ultima Condensor Dryer
on the back of your dryer you have a heater behind the protruding panel... Either you heater element has gone, but most like the thermal cut outs have blown...these are located in the same area..they are small and round looking and are connected to them are wires either side. Anyways check the conitunity of the termal cut outs using a tester if no continuity then they are no good... hope it helps...
Nov 18, 2007 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
504 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
