Question about Lexmark Z1420 Printer
I cannot get the printer to connect with my laptop, i have installed the disc that came with it, however the "wifi" indicator on the printer remains in "off" mode. the laptop keeps tellling me to " enable bidirectional communication " in the printer properties dialogue, only i still cant get it connected. any advice would be gratefuly recieved. michael
  • Lexmark Master
  • 12,061 Answers
You enable "Bidirectional Printing" in the BIOS in the Printer or Parallel Port setup. It is a Mode of the LPT or printer port.
Posted on Feb 04, 2010
Printer is ccted to wifi. so is laptop. when I go to print it just says getting printer information. how do I connect
Unplug and shut off all devices, restart and see if connection is made. Was the driver disc installed in laptop for this printer? Might have to create a new wifi network if communications are not being made.
May 07, 2015 | Canon Pixma MG5220 InkJet Printer
Hp pavillion laptop allows me to log on. Then as it loads up screen flashes and a blue circular disc appears by the curso. It says limited wifi. No problem with the WiFI connecting my phone to it.
Does your phone use the Wifi antenna from your laptop? or the receiver? or the software? When your laptop indicates it has a problem with the Wifi connection, it has. What is causing this should be looked after in the laptop, like did you setup the connection correct? Is the setting still correct? or did something change the settings or even reset the settings?
Just check everything about the wireless connection in the laptop to see if you can get it working again. If it was never working before, just setup the connection.
Apr 17, 2015 | HP Computers & Internet
How to install a printer on laptop?
If you don't have the original installation disc, look at the brand and version of your printer. Go to the main website for the manufacturer and search for the version of your printer. There should be a download available. Download this to your laptop. Use a USB cable or the cable that comes with the printer and plug it into your computer and the back of the printer. After you've done this, run the installation software on your laptop and follow the instructions. Unplug when the installation is complete, or if you have wifi and the printer is compatible, follow the instructions to also connect it for wireless printing.
Oct 31, 2014 | Office Equipment & Supplies
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
Why won't my printer scan a document to my laptop?
Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Dec 01, 2011 | Lexmark X5650 All-in-One InkJet Printer
Why isn't it scanning a document to my laptop
How to connect new laptop to router
Hello
In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
Click on "Properties."
Select the "Wireless Networks" tab.
Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
Click on "Configure" when you see your network's SSID in the "Available Networks."
Enter your network's SSID and WEP key.
Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
Hope it helps, if so do rate the solution
Good luck
Dec 24, 2010 | Linksys Wireless-G WRT54G Router
I just purchased a laptop and was trying to setup my printer on it and the Wifi indicator light isn't lighting up at all?
Hello
Turn on the wifi on printer, install printer drivers to your computer and detect your device on computer and press connect,
Feel free for more assistance
Hope it will helps, do rate if so.
Good Luck
CMPTRLINK
Dec 12, 2010 | Office Equipment & Supplies
How do install one of my printers to my Acer Notebook?
usually the printer will come with a disc to install the software, if not you can plug your laptop into your printer via an ethernet or usb connection, some of the newer printers will have wifi on them so you can search for it wirelessly, hope this works
Nov 21, 2010 | Acer Aspire One PC Notebook
Acer aspire 4736z wifi problem
1.format and reinstall the Windows 7(or) Vista.
2.install the drivers using motherboard disc
Note: some of the acer laptops doesn't work with windows xp with efficient manner like this.
Mar 10, 2010 | Computers & Internet
Lexmark Z1420 Printer Logo
333 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
