Question about Acer Aspire 6930-6455 Notebook PC
How do you take the acer aspire 6930 apart to put in the bluetooth module,and if I have to remove screws under dvd drive how do I get out a stripped screw? Please give step by step advice and list tools needed. Thanks
  • Acer Master
  • 12,061 Answers
You need a fine Philips screwdriver, or if they are Torx screws then a fine one of those. For a stripped screw... well an eze-out tool, or a fine drill. Sometimes you can use a fine nosed pair of side cutters and grip it and twist.
Posted on Feb 04, 2010
How instal bluetoth to acer aspire 5560-7851
This unit does not have bluetooth, it is a manufacturers option which means it is fitted at the factory, you can buy a bluetooth module, but this would mean stripping the unit to mainboard as it has to be connected directly and if under warranty this would be void, unless fitted by Acer.
Jun 01, 2014 | Acer Aspire 5560-7851 AS5560-7851 15.6"...
How to reomve a faulty CD/DVD drive from the Acer Aspire 5510 to enable replacement.
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
Jan 10, 2011 | Acer Computers & Internet
Aspire 6930 has a bluetooth button when pressed says no device
There has to be another bluetooth device within range and turned on before it can find a device or of course you will get that message
Oct 31, 2009 | Acer Aspire 6930-6941 Notebook
How to replace the DVD drive on Acer Aspire 5002
I actually had to permorm this action yesterday.
First remove the small strip above the keyboard by unscrewing the three screws at the back of the machine that hold it; then twisting the screen al the way back and lifting it up.
Second unscrew the keyboard (2 screws) and lift it away (don't detach the cable).
Third: on the left side under the keyboard unscrew 3 screws that hold the cdrom in place.
Pull the drive out. The rest (taking the case of the dirve) should be transparent.
There is nothing on the bottom you have to unscrew!
anthon@mnt.org
Oct 07, 2009 | Acer Aspire 5002WLMi Notebook
Acer 5315 broken hinge help!
the hinge may be under the power bar
a few screws, and are also connected to the brackets that run along the lcd,
the unit basically has to be taken apart completly
Jul 20, 2009 | Acer Aspire 3050-1733 Notebook
MY ACER ASPIRE IS NOR PLAYING BLUERAY DVDS
The Acer Aspire 6930-6771 does not support Blue-ray disks only dual layered DVD's,
Specifications for Aspire 6930-6771
  • Intel® Centrino® 2 Processor Technology
  • Intel® Core™ 2 Duo Processor T7350
(3GB L2 Cache | 2.0GHz | 1066MHz FSB)
  • 16" WXGA Acer CrystalBrite™ TFT LCD (1366 x 768)
  • 3GB DDR 667MHz Memory
  • Integrated Intel® Graphics Media Accelerator 4500HMHD
  • 320GB 5400RPM SATA Hard Drive
  • Super Multi Double-Layer Drive
  • 5-in-1 Digital Media Card Reader
  • WiMAX Forum Certified™ WAN/802.11a/b/g/n
  • Acer Crystal Eye Webcam
  • Dolby Home Theater®
  • Windows Vista® Premium
Regards.
Jul 14, 2009 | Acer Aspire 6930-6771 Laptop
Acer Aspire 6930 won't play Blu Rays
Your DVD is not Blue Ray capable. You would need to purchase a Blue Ray DVD player for your laptop, just having the software does not allow you to read them.
Apr 11, 2009 | Acer Aspire 6930-6455 Notebook PC
How do i activate blutooth on my acer aspire 6930?
Have you looked to see if there is a bluetooth software bundle that came with your computer? If there is it should be as easy as finding the program on your computer that runs the software. Once you locate the program you'll have to setup the software with your bluetooth device. If you do not have a bluetooth device, setup will not work as it needs the device to automatically sync with your computer.
Dec 10, 2008 | Acer Aspire 5500 5570-2609 Laptop
Open Questions:
Acer Aspire 6930-6455 Notebook PC Logo
589 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
