Question about Canon Office Equipment & Supplies
CANON iR6800-touch panel displaces 2cm to the right related to lcd screen. When adjustment is done, after few minutes, it displaces again. I tried to replace control panel assy. but trouble remains. Any ideas?
  • 58 Answers
Check the connector on the panel side and then on the dc controller side
Posted on Feb 10, 2010
What does e000003-0002 on canon ir c3380i,e000025-0002,e000045-0000 refers to?
Hi. That error ( 0003-0000) is related to the fixing unit. You need to clear it from service mode first.
You need to be quick doing the next process because machine will automatically turn off after a few minutes.
With the copier turned on press the next key secuence
Press adittional function
Press 2 and 8 ( at the same time )
Press additional function.
Service mode should appear in the screen . If it doesn't repeat the secuence until it does .
When service mode appears press in the touch panel COPIER
Then select FUNCTION
Then select CLEAR
then select in the lower list ERR
Then press ok in the lower corner
Turn off the machine from main Switch. Wait a few seconds and turn it on again .
Try to make some copies . If error persist there is a malfunction in the fixing heater and need to be replaced
The other error is related to the developing units
Jun 24, 2017 | Canon Office Equipment & Supplies
Ir3235 canon system code E000002-0000 Solution to fix this problem
Hi. That error is related to the fixing unit. You need to clear it from service mode first.
Then select CLEAR
Try to make some copies . If error persist there is a malfunction in the fixing heater and need to be replaced.
Mar 30, 2017 | Canon ImageRUNNER 3235 Black and White...
Hi, my tv screen goes blank after a few minutes usage, I still get sound tho.
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
often that *needs* to be done in a service center as there are some adjustments to be made after replacement.
Hoping this will help in solving the problem...
Aug 05, 2011 | Televison & Video
Displacement for colour copy horizontal with the itb belt, I am sorry I do not have a credit card
Additional Function key>adjustments and cleaning>auto gradation>choose quick adjust first > then do full adjust.Should print 3 pages follow instructions on screen. If this does not do it the ITB needs to be taken apart and the rubber rollers cleaned. DO NOT CLEAN the foam rollers there should be 4 foam rollers at the top don't even touch them as they will be damaged. Simple Green or 409 degreaser should work fine to clean them. Try not to touch the ITB or kink or wrinkle it during disassembly.
Jun 30, 2011 | Canon imageRUNNER C3200 Copier
TV have sound but on picture, screen is black, can change channels, TV works like radio
You can solve this type of problem by opening the television, but caution must be taking to ensure proper troubleshooting, because the panel contains high voltages.
Often there are fuses on that board - one or more. Check those.
often that needs to be done in a service center as there are some adjustments to be made after replacement.
Hope this will help in solving the problem....
May 09, 2011 | Samsung LN-T1953H 19 in. LCD HDTV
I have a ricoh 1045 , and I can not read the display looking down, but I can see everything in an angle. Can you help?
See the display panel contrast button position(in the left side to user tools button.).If not work perform the touch screen adjustment:Press the total stop key(yellow)-1-9-9-3-clear/stop key(red button) x5 timeand press enter key(double croice).The graphic sensing adjustment screen will appear.Touch the upper left corner then the lower right corner of the panel using a pointed tool.Touch a few spots on the LCD and confirm that the marker appear on the screen at exacrly the same location as the pointed tip.Touch enter on the screen adjustment.Turn off the machine and back on to store the settings.
Sep 26, 2009 | Ricoh Aficio 1035 Copier
The touch screen only selects lower part of the
my screen is not working properly
what should i do
Jun 23, 2009 | Sony Ericsson P990i Smartphone
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
CANON IMAGERUNNER 330S TOUCHSCREEN
Start with service mode, Additional functions(looks like * key), then 2,8 together, then addit. func. again. Has to be a fluid motion. If done right you will see a screen with copier, and whatever options the copier has. Hit copier key. Hit function key. Hit panel key. Hit touch key option, hit OK. Then touch the nine + signs. once complete. press reset to get out and test results. Hope this helps.
Jun 13, 2008 | Canon ImageRUNNER 330s Copier
145 people viewed this question
old marine
old marine
