Question about Electrolux Epic 6500 Vacuum
Vacum runs fine with hose disconnected and soon as any pressure is put to hose recepticle including your hand it shuts off
  • Electrolux Master
  • 12,061 Answers
These machines have a "Suction" sensor this has become blocked or gone faulty, or the microprocessor has... yes there is one in here too. Probably going to have to get it looked at?
Posted on Feb 04, 2010
Electrolux 2100. runs fine without the hose as soon as suction is required the machine shuts off
The control panel on the top needs either repaired or changed.
That will take care of your issue
Jul 07, 2017 | Electrolux Vacuums
Shuts off for unknown reason
I sold them for 15 years and I was a service manager for 5 years. This is the classic symptom for a broken diaphragm in the control module. Please contact your local AERUS service facility. They will have the part and will install it for you. This is not a DIY type of fix.
Jan 29, 2012 | Electrolux Epic 6500 Vacuum
The vacum will run until the hose is inserted and then the motor shuts off. The vacum switch must be hooked up incorrectly. Do you have a schematic?
Before trying to take it apart, check the hose for a blockage. Disconnect the hose at both ends, drop a coin in one end, lift that end of hose allowing coin to drop through. If it doesn't come through, there's a clog. You should be able to clear it by plugging the hose into the exhaust port of the vacuum, holding the other end to the in port, and turning on.
Another possible problem is a dirty afterfilter. Remove the air diffuser/tool holder on the back of the vacuum. If the filter is dirty, it blocks the air flow and the vacuum will shut off due to overheating. Remove it, connect the hose, and turn on the vacuum.
If you don't have a manual, you can download it at the below site. Click on the space under "older models", click on Ambassador III, and download.
Information for removing the air diffuser is on page 9.
http://www.aerusvacuums.com/support/manuals/
Feb 13, 2011 | Electrolux C101 Bagged Canister Vacuum
How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
Dec 30, 2009 | Dirt Devil Vacuums
I have no suction on the Lindhause healthcare pro Hepa
Make sure that the on switch is in the upright position. Down won't give you give you suction when vacuming.
Make sure that the hose is securly in the lower part of the vacuum.
Test the hose with your hand before you put it back to see if you're getting air sucked in through hose. If not it must be clogged up somewhere. You might contact Lindhause home base.
Feb 23, 2009 | Lindhaus Healthcare Pro 14 Bagged Upright...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I have a central vacuum system. When I disconnect the hose from a wall outlet the central canister does not shut down dispite my turning off the vacuum at the handle of the hose. The only way I can get...
What I'm hearing is the canister(Not the Powerhead) portion of the unit is running all the time unless you unplug it. this problem could be caused by a short in one of your low voltage lines running through the house. To determine that just unplug one/both low voltage lines from the canister, and plug it back into the recepticle. If it doesn't start up then you figured out that it is in the house somewhere and not the unit. If it is in the house I would check for water in the valves, or you're just gonna have to chase down the short. If the unit is still running with the low voltage wires disconnected then it is probably the relay on the board, which means you will need a new board unless you're expereinced at soldering and want give it a try replacing just the relay. Which you'll probably need a new board by the time you're done anyhow. LOL
Good Luck
Nov 21, 2008 | Vacuums
Vacuum shuts off
if you want to fix this problem gently pry up the air flow control knob and look down at the plastic hose connected below the control valve. insert a small screwdriver and push off the hose from the valve. this disconnects the bag full indicator but will let the vacuum operate normally at full vacuum. you will change the bag when suction gets low. this will save you at least $100 repair bill.
Dec 31, 2007 | Electrolux Lux 5500 Canister Vacuum
Vacume cleaner
Check the hose and see if it has a clog, also the hose at the bottom. The filters may be clogged, make sure they are clean and that air flows thru them, if not then replace them.
Dec 09, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Same Shut Off Problem as Hamster71
The part that you call the particle size sensetivity adjuster is bad. There are 2 seals in the assembly, the lower seal is slipping out of place because the plastic lip which keeps it in place is broken. Split housings and replace part. This machine is alot of work to take appart and get back together correctly. Might want to bring to local vac shop. good luck.
Nov 15, 2007 | Vacuums
Vacuums Logo
131 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
