Question about Panasonic PT-LB10VE Multimedia Projector
Standby Light on PTLB10VE (Panasonic) is allways on.
How can I return the projector back to normal use???
  • 126 Answers
Replace power board: ETXMM519MBGB
Posted on Feb 04, 2010
Just recently paid $836.00 for projector repair. Unit would not power ON, power indicator flashing 3 times. They said they replaced the DMD board. We asked to see the replaced part but they did not have...
If unit is working now, the repair is valid. Parts, like DMD are quite expensive and require core to return. Example: Main Board for Panasonic plasma TV cost $525+. When repair shop return a dud(core), they get $250 credit. Even some used parts, like light engine, require dud return(if you wish, of course) to get $50 back. So: now you know how it works. I won't blame them for immediate dud return, due to high cost of the part(s).
Especially for Panasonic. For the boards they require prior authorization. I've got into that mess couple times. Hope, that repair worked out well for you. If not, I might give you a second opinion, but I need to see and open your projector. It's up to you.
Sincerely,
Alex. C/o Alex's Television, 215-806-5980(Philadelphia, PA)
Dec 08, 2011 | Panasonic PT-D5600U DLP Projector
Toshiba TLP s30 projector identification part
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Plcxu41 standby mode how is this setup?
This unit will go into standby if no signal is present for a few minutes. Pressing any button will return it to normal operating conditions.
Hope this helps.
Nov 15, 2010 | Sanyo PLC-XU41 LCD Projector
My projector pt-lb10e cannot start up, the standby light is on but when try to press the on button nothing works. How can i reset the projector?
The "CONTROL KEY" may be set to "OFF".
In order to set the "CONTROL KEY" to "ON" without using the remote control unit, keep holding down the ENTER button on the projector and press the MENU button for more than 2 seconds.
Sep 16, 2010 | Panasonic PT-LB10E Multimedia Projector
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Panasonic PTAE 900U with new lamp and counter reset shut off
Reseat the lamp.  I had a similar problem.  Replaced the lamp and everything worked for about 3 hours.  Then, turned the projector off.  Next morning, when I turned it on, nothing.  Stanby/On light flashed green for a minute then the lamp light came on and the projector went into standby.
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
Faulty Panasonic Projector
90% that this is a bad psu !
had mine fixed today with used psu from ebay.
try to find a faulty pt-ae900 for a exchange psu !
60€ faulty projector + 60€ psu = 120€ for pt-ae900
hooray :)
cheers,
tobias
Dec 31, 2008 | Panasonic PT-AE900U Multimedia Projector
Projector Panasonic PT-LC50U
MI PROYECTOR PANASONIC PT-LC50U ,SOLO ENCIENDE DE 2 , 10 NINUTOS LUEGO SE APAGA Y SE ENCIENDE LA LUZ O SALE LA LETRA L-n QUE DEBO DE HACER POR AQUI NO HAY CENTRO TECNICO ..
MI CORREO ES : jcasaperalta@hotmail.com
gracias por darme solucion.
Sep 18, 2007 | Panasonic PT LC50U Multimedia Projector
Blub goes out during use.
Most fans have a sense line to detect the fan is working properly, Possible the sense circuit has failed. The unit should not start if it thinks the fans are not running. Possible thermal problem with the sense circuit, since your unit starts up then stops.
Mar 10, 2007 | Toshiba TLP-ET1 Multimedia Projector
Panasonic PT-LB10VE Multimedia Projector Logo
209 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
