Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Missing disc for the router & router is disconneting from the internet.
    Scholar:
  • 61 Answers
You have not supplied the manufacturer's name but if you can access the web from another network connection the best thing to do would be to look up the support site [again, you didn't provide the name of the maker so I can't supply it for you here] for the router in question. There you would have access to the firmware update file(s) you will need to resolve your problem.
Copy them to a USB key drive or burn them to CD-ROM and use them to flash the chipset and correct any corruption of the current firmware you believe might be the source of your issues.
DO REMEMBER to use the administrative interface for your router to save any settings you may have previously made to a file to easily restore them after updating the firmware, as all settings will have reverted to factory defaults after doing so.
Posted on Feb 04, 2010
Belkin Startup Disk missing
The startup disc is not really required on most home wireless routers. Simply connect the ISP modem to the main port on the router and connect the pc to any other port. You should have internet via wire at this point.
You will have to reset the router by holding in the reset in the back till it cycles. This will clear all custom settings. Then simply use the defaults to log into the web admin if need be, or to setup a wireless key for protection.
Feb 11, 2013 | Belkin (F6D42304) Wireless Router
Nstallation cd is missing for DIR-600...Hello, If you don't have the installation disc anymore, you can...
open the setup page of the router and change the settings manually.
Like other routers, you can install wireless router without installation CD also,
Read how to setup router without installation CD
Jul 04, 2012 | D-Link DIR-600 Router
There is an orange flashing LED internet light on our netgear router
as per your router's manual
the light color is called amber and it means that you router is connected (ethernet cable going to your modem) but you're not getting an ip address from you the ISP, check with your isp after attempting to reset your modem (disconnet power and signal cable from modem wait a few seconds and reattempt to connect modem). if problem persists go ahead and check with the ISP.
Jan 01, 2010 | NetGear WGR614 54Mbps Wireless Router...
I have lost the disc to my Zonet Wireless internet router
Consider visitin the manufacture website if u have access to internet.if not.
Contact any hardware Vendor nearest to you they may have the router and help u
burn the drivers into an emty CD
Dec 31, 2008 | Zonet ZSR1114WE 802.11g 54Mbps Wireless...
Internet is constantly disconneting and reconnecting
This is a firmware problem of your router, the firmware is the software of your router and its should be updated , just downlaod the latest firmware from Netear wen site and if you don't know who to update the firmware you can contact this number so a technician can walk you through and solving your problem and updating the firmware of the router 1-877-787-8749.........
Oct 18, 2008 | NetGear RangeMax WPN824 Wireless Router...
Connection trouble
I purchased linksys WRT54G when I connect the second wiring I
lose my internet. My wireless use to work but since I disconneted it and reconnected the wireless does not work.
Jul 11, 2008 | Linksys Wireless-G WRT54G Router
I am disconneted from the internet i have already spoken to my internet provider and also my laptop company they are telling me that the promblem is that my router is not connecting
i would suggest unplugging the power from the router waiting 10 secs and reconnecting and seeing if this fixes your problem if not , do a cold reset hold down the reset button on the router usually for a few seconds and then go ahead and re-input all the settings that you need.
If this still isn't working i would assume that you try this router on another working network and see if it can connect if not , i would think that the router is losing its routing tables and is unable to route past your own LAN , the best solution for this is to invest in a new router.
Thanks!
Apr 14, 2008 | Computers & Internet
'Cartridges Missing' error. I have just replaced the belt on my 750c plus and reassembled. However when I restarted the plotter, the plotter does not recognise the print cartridges promoting 'Cartridges...
HP 750C Black cartridge quit in the middle of plotting chart. Replaced black cartridge & does not make contact with something. Cleaned contacts, turned off plotter, disconneted cables, reconnected & turned back on. Still says that black cartridge is missing. HELP!
Dec 11, 2007 | HP DesignJet 750c plus InkJet Printer
Cannot connet to internet
Device communication issue! This sometimes occurs fro many reasons mainly FIREWALLS~ In order to keep this from happeninig you should probably setup a static address on your laptop or if your network has a SSID, it needs to be manually set into your adapter because it is not picking up your network. This often happens when you use your laptop in or on other networks. Easy fix, but need answers to these questions!
Nov 25, 2007 | SMC Barricade g SMC2804WBR Wireless Router
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
