Question about Fisher Freezers
Does this freezer have a temperature control you can use when filling with meat to quick freeze?
  • 52 Answers
I'd check the manual, if you don't see a manual control on the freezer, I don't think there is a quick freeze control on that model.
Posted on Feb 04, 2010
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
Freezer wont shut off
This is more than likely a sign of Freon issue, where the machine runs non stop trying to reach a temperature that it never does. Even though things are freezing, like meats and such, they have water in them and that freezing point is 32 F. Check the ice cream if you have it in there, does it seem softer than normal, or not as solid as you like. If so, you have a leak and a tech should be called
Jun 22, 2012 | Electrolux Freezers
Upright Freezer not cold enough
Honestly it sounds as if you have a sealed system issue, most likely low on freon.
Jun 13, 2012 | Freezers
My freezer does not keep my ice cream hard, yet it freezes meats, etc. without a problem. What is wrong?
You don't note whether or not you've adjusted the thermostat. Ice cream (and juices) requires at least zero degrees, if not minus 5 degrees, for storage. Meats, fish, bread, etc. can become rock hard at much higher temperatures. Try setting the thermostat lower.
Jun 07, 2011 | Freezers
I need to know what the numbers mean on the temperature setting (1-7) for my Gibson Upright Freezer? What is best recommended temperature?
The highest number is the coldest setting.When you fill it up with food to freeze , set the freezer to the coldest and after everything is frozen .set the control to the middle.
Oct 05, 2009 | Freezers
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
We have a 20.3 cubic feet Kenmore upright frost free freezer we purchased in May 2003. We noticed the meat was beginning to thaw one afternoon. We hit the quick freeze button and that seemed to fix the...
This sounds like a bad thermostadt, since the quick freeze button does work. But it should be much colder than 32 degrees. It may also be the motor, since it runs for brief periods of time after plugging it back in.
I'd say best bet here is to call a repairman. (sorry...)
May 10, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer Burn
It sounds like you may be overloading your unit. If you place a large quanity of non frozen items in the freezer at one time, it may take a few hours to bring the temperature back down. This usually happens with a chest type not an upright. Insure when adding items to the freezer there is room for air movement. With out looking at it I think the problem is the defrost timer or sensor. Maybe staying on too long increasing the overall temperature of the unit. When ever the defrost cycle is on, the cooling unit is also off. As far as the meat freezer burning, none of the freezer bags I have used prevent this. I pr-wrap my meat in freezer paper and then place it in a bag, sometimes freezer bags sometimes not. I try not to buy meat from grocery stores, I grow my own meat and have it butchered and vacuum packed, it doesn't change color. Please note that items in a freezer bag moved around after the contents have frozen will cause air leaks in the bags very easily.
Nov 26, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
96 people viewed this question
Top Fisher Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Fisher Freezer Expert? Answer questions, earn points and help others
