Question about AEG 18 in. Favorit 64800 Free-standing Dishwasher
When my dishwasher has finished its full cycle all my glasses are cloudy and cups tasts like they have a salty residue on them, if i rinse them under the cold tap there fine please advise
  • AEG Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 01, 2011
SOURCE:
I have a Maytag dishwasher model #MDB7160AWW. I am finding a cloudy residue on my glasses and cups on the top rack. Our water is hard. When the washing cycle is completed, there is still soap residue...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
Apr 14, 2011 | Dishwashers
New soap and rinse dispenser was replaced on August 12,2010,now glasses are coming out with hazy film on them. Rinsing agent does not seem to be coming out of dispenser
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Dec 12, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
I bought this dishwasher 2 weeks ago. The dishes are not always clean, the glasses on the top rack have a residue that gets dried on (white/gritty) and the glasses have a white film on them. I have...
Nov 06, 2010 | Viking VDB450 Dishwasher
Glassware not clean
Jul 07, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Cloudy glasses My dishes are not being cleaned. There is a white residue on my glasses and in the dishwasher itself.
You may have hard water. Are you using a rinse aid, you always need to use one. Buy some Tang drink crystals and empty a package into the soap dispenser and run the dishwasher through empty. If you can't buy Tang use about 4-6 cups of white vinegar thrown in the bottom of the machine and run the cycle. Sometimes the white residue on the glasses is there permanently and can't be removed it is called "etching" right in the glass.
Jan 26, 2010 | Kenmore Elite 45986 Front Load Washer
Clear glass dishes are cloudy. What is causing it? We have checked the arms--they seem to be working fine. Some days it does better than others--today they were extremely cloudy. I washed the glasses by...
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is due to hard water deposits; make sure the salt reservoir is topped up. Do not worry about over-filling it.
If the cloudiness is not removed, it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. Dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Dec 17, 2009 | Dishwashers
Cycle timer displays very different times for cycle, cleaning is not particularly good. Problems related? glasses appear filmy, even when rinse agent is used.
your dishwasher uses an optical sensor to constantly monitor the water turbidity or cleanliness if it detects the water is cloudy it will extend the wash time and vice versa there are several reasons for cloudy glasses check to see if they taste salty,or if the cloudiness washes off,this usually happens when the baskets are loaded badly and the detergents/temps are not set correctly.
Nov 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes have filmy finish
hello. this will help a great deal.
First of all empty out your dishwasher, toss in two cups of plain white or cider vinegar and run it on the highest and longest cycle.
Always run the hot water in the sink first and start the dishwasher only when the water is as hot as it will get.
This wash will clean out your dishwasher thoroughly.
Then always do your dishes after you have rinsed any residue off of them before placing them in the dishwasher and I always recommend the pot scrubber cycle if you have one.
Jul 07, 2009 | Dishwashers
Kenmore Dishwasher 363.165 model not rinsing right
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
ewe
Mar 11, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Open Questions:
AEG 18 in. Favorit 64800 Free-standing Dishwasher Logo
261 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
