Question about Dell Inspiron 1545 Notebook
No audio output to tv on my dell 1545
I am trying to connect my Dell 1545 to a TV for video ouput. I'm using a VGA > VGA connection and the picture is transferring perfectly. However, I can't get the audio to output to the TV. I'm using the Laptops 'Headphones' output socket and the TV's L&R Audio input sockets with a 3.5mm Jack 2 RCA Phono Audio Cable. The exact same setup used to work on my old laptop without any problems. When I listen to music on the laptop via headphones the sound outputs perfectly. Can anybody help?
  • Dell Master
  • 12,061 Answers
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Posted on Feb 04, 2010
Testimonial: "Thank you for the response - will try this and see if it works"
How do i use my tv sa a monitur for my pc but has no VGA on the back just a HDMI plug and scart socket.
Chris, what happens when you plug the hdmi connector into the TV and your adapter, while your computer is running and connected to the adapter?
Are there drivers required for the adapter?
As an alternative, you could install a video board in your Dell that includes an HDMI output. I have a laptop with one, and connect it to my TV often; works fine.
Jun 19, 2015 | Dell OptiPlex 745 Desktop/ Mini-Tower/...
How do i get audio to philipspfp5332d/37 using hdmi2 vga converter when tv input is locked in safemode
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=us&ctn=50PFP5332D/37
frequenly asked questions- you will probably need to also use an aux sound input in conjunction with a video cable if you are not using an hdmi connection, read the article above for confirmation.
Feb 01, 2015 | Dell Computers & Internet
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Can you help with my Dell inspiron 1545 VGA problem?
Laptops use shared RAM memory, it uses part of the main RAM.
If the RAM is faulty or not making proper electrical connection it affects the video.
Reseat the RAM module/s and if this does not fix the problem, remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM.
Apr 01, 2012 | Dell Inspiron 1545 Notebook
Hi i'v bought a LG LD 310 lcd tv and i want to
I tried this.. and it works perfect for the video.. but there is no audio.
Is there any specific setting to be made in TV or my laptop?
I have Dell laptop with Win7, because I dont see any option to enable audio..
Aug 01, 2011 | LG Televison & Video
Trying to connect my inspiron 15 to my toshiba 32af44 and i can't get a picture on my tv. I have bought a pig tail that goes from VGA(the lap top side) to s-video/audio-video cables(tv side) but still...
A simple pigtail won't convert VGA to S-video. The VGA output consists of separate RGB lines and horizontal and vertical synchronization lines.
If you have an adapter that really converts VGA (this output has no audio path) to S-Video and audio lines, then you probably just need to re-select the input through the TV's menu system.
Nov 21, 2010 | Toshiba 32AF44 32" TV
Taptop connect to TV audio preoblems
Hi there.
If your TV supports a VGA cable it should also support computer audio in. You need to purchase a mini stereo cable and plug it in to the headphone socket on the laptop and run it to the computer audio in on the TV,just using the VGA cable alone will not produce any sound.
Purchase something like this for the audio >>>>>>
Good luck and thanks for using FixYa!!
May 23, 2009 | Dell Inspiron 1525 Notebook
Can I connect my dell latitude d360 laptop to my tv?
you need to have the same connections on both my laptop has svideo or vga connector, some have Hdmi which is the newest, but the tv and laptop have to bot have the same connectors, it may be a dvi, or any that I mentioned, then you need a cable for your video, and another for your audio, both the audio and video cables are run to the tv, the only one that has both audio and video is the HDMI which tv's from the last hear or 2 usually do have. Then depending which input the laptop is using which it will tell you where the connection for the tv is, you set it to that input and that turns your tv into a giant monitor
Dec 22, 2008 | Dell Latitude D600 Notebook
Dell Inspiron 1545 Notebook Logo
718 people viewed this question
Alun Cox
