Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
I do not know how to find the AV program, so as
I do not know how to find the AV program, so as to connect my PS3 to the Hannspree LSD
  • 1,472 Answers
Odusotegeorg
I am not sure what you mean by the "AV program". I am going to take a guess that you mean the video input channel. Well with monitors they really do not have those.
If you can let me know the exact model of monitor you have an can double check your connections and setting for you.
Now since you have a PS3 the best connection for you to be using is the DVI port on the monitor. Now since most monitors do not have an HDMI port you will neeed to get a HDMI to DVI cable.
Let me know if this is how you have it connected and are still having trouble getting the monitor to work.
Issken
Posted on Feb 18, 2010
My monitor was working perfectly fine until I unplugged it to play on ps3 so when i did the ps3 wouldnt connect i tried holding down the ps3 button nothing so i plugged back into laptop no connection.
Have you used the HDMI cable with the PS3 before? it may be configured to use the AV connection. If so plug in an AV lead, then you would need to find in the settings to change the output to HDMI.
The HDMI cable may not work
Press windows key and P to switch between monitor modes
Try those and post back if you need more help.
Mar 30, 2015 | Hannspree HF199H 19 Flat Screen LCD...
Cannot get it to connect to monitor
Hi, What model Hannspree is it? you might have the resolution set too high for the monitor!
Sep 23, 2007 | Sony Playstation 3 (PS3) Console
I have a 42" Hannspree TV. What channel do I put
h;
your DVD player has an output of Audio and Video, and at the back of your TV has and input A/V
you have to connect a RCA cable to this inputs, your RCA must have 3 connectors yellow for video,red for left channel audio white for right channel audio,
then set your TV to AV1 if connect it to AV input 1,there are two AV input at the back,and also SVideo input,
you have to set it by pressing INPUT or TV on remote or button of your TV.
Sep 03, 2011 | Televison & Video
How can i get my ps3 to use the av cable instead of the HDMI cord
Hello there,
There is no way to connect an AV cable directly to a PS3; however, you can purchase a special cable that convert the HDMI to AV. Here is one such cable. http://www.amazon.com/Universal-S-Video-Audio-Cable-GameCube/dp/accessories/B000IAPGII
I hope this has helped! Thumbs up are much appreciated.
May 06, 2011 | Video Game Consoles & Games
How to connect a ps3 to a hannspree television
You can connect over HDMI connection or via the composite cables that would also be known as A/V. Those are the red, white, and yellow cables.
Mar 01, 2011 | Hannspree (K206-10U1-005) Television
I have a ps3 60gb capatible for the ps2 I have it hooked up to the TV but its not showing anything on the TV I have the High Def connectors for the TV
It is a known problem with some high def connectors not working properly. The following should be checked before concluding there is a problem
1. Ensure you have your TV tuned to the right output station for as your ps3 is connected.(for example you cannot have your ps3 connected to the second set of av ports on your tv and your tv is on av1, it has to be on av2)
2. Cross-check the functionality of your ps3 using the default av cables that come with it so as to know if your cable or console is faulty.
3. Ensure that you high-def cables are properly connected.
If all the above prove abortive, you have to see a repairer to check-up your ps3 or tv
Dec 25, 2010 | Sony PlayStation® 3 (60 GB) Console
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    I tried to hook up my ps3 to my hannspree monitor
    did you hook the dvd player or xbox 360 to see it if still works after ps3? if still no result, it's most likely that the motherboard in the lcd shorted out.
    Oct 16, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
    I need to know how to run my ps3 thru the optical wire to my hdtv
    Before you start ensure that you read the TV instruction manual to know which resolution supports it. Do not switch on the TV and your console
    You can connect your Playstation 3 to your TV in three different methods:
    1. Connecting with an AV cable
    2. Connecting with an HDMI cable
    3. Connecting with an Optical Cable
    Connecting with an AV Cable:
    1. You are supplied with a Composite AV cable which would typically look like the below image
    2. Connect the AV Multi Out Connector to the socket on the back of your PS3 Console.
    3. Match the colors of the Jacks with the connectors on the TV which says "Video in".
    Connecting with an HDMI Cable:
    HDMI cable is not supplied with the PS3. You need to purchase it seperately. This cable would enhance the audio-video quality of your TV.
    1. Just connect one end of the connector to the HDMI OUT connector socket on the back of the console
    2. Connect the other end to the socket on the back of your TV which says HDMI IN.
    Connecting with an Optical cable:
    You need to purchase an Optical cable if you wish to connect your PS3 console through a digital audio device (Home theater, AV receiver etc.,). You need to connect Video ouput seperately with a help of Video output cable (HDMI, AV Cable etc.,)
    1. Connect one end of the optical cable to "Audio Out" socket on the console
    2. Connect the other end to the audio receiver.
    Note: You can also connect your console to the Internet to use the Playstation 3 internet capabilities. Here's how you do it:
    The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type networks. It needs a High speed internet connection. Do not connect it to a standard telephone connection or cables that are not supported. It might cause a malfunction or damage to the system.
    Dec 11, 2008 | Computers & Internet
    PS3 No picture or sound
    When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
    Jun 25, 2008 | Sony Playstation 3 (PS3) Console
    Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
    147 people viewed this question
    Top Hannspree Computers & Internet Experts
    justwinwin
    Computer Links
    Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
