Question about Kodak EasyShare C340 Digital Camera
Battery door retaining lugs broken,also the plastic lugs on the main body that the battery door needs to latch onto are broken off ,cannot use camera as unable to secure batteries in the camera ,door will not remain closed--otherwise working ok
  • 1 more comment
  • Anonymous Mar 12, 2014
    Gf1 battery door latch broken
    Gf1 panasonic battery door latch broken
    Genius:
  • Kodak Master
  • 1,099 Answers
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
Posted on Feb 05, 2010
The door that keeps the batteries and memory card will not stay closed. Can it be fixed?
Mine is broken also. There are 2 tabs in the cover and 2 raised slots on the camera body. When you open the battery compartment, you are supposed to slide the lid forward releasing the tabs from the slots, before the cover pops open. If you don't do this, you ~will~ break the tabs (or the raised slots). Well someone who didn't know this got a hold of my camera tried to force the compartment door open, breaking the raised slots that are part of the camera body.
Take a close look at yours and figure out how this latch is supposed to work and then see which part is broken. If it's the tabs on the door you can buy a replacement door online (do a search) and have someone good with electronics install it. (requires soldering). If (like me) it's the slots on the camera body that are broken, then it's not repairable. The original parts are too small and flimsy to be repaired (designed to fail). My best idea is to find some other way to latch the door closed. I've tried a velcro strap but it doesn't hold the lid tight enough and I've looked in hardware and craft stores for some kind of latch that might work, if I could atach it to the outside of the door somehow, but haven't found anything suitable (it would have to be small but sturdy and attach to the thin plastic of the door)
I'm thinking of taking it to a jeweler because they work with very small parts and might have something that could be screwed into the plastic door and camera body.
If you know of a better fix, please let me know.
Jun 15, 2010 | Canon PowerShot A720 IS Digital Camera
Fuji S5000 camera problem....The battery door will not latch because the cheap plastic retaining nipples inside the battery box have worn down/or broken. Tape will not even hold door closed! The retainers...
You could use a piece of velcro as a strap but I would start looking at ebay or other places for the parts to fix it. Sooner or later someone will sell it.
Mar 23, 2010 | Fuji FinePix S5000 Digital Camera
Broken latch on film door
Usually on this level Nikon it was a plastic "hook", part of the door moulding, that was retained by the latch mechanism in the body. The broken part may still be in there - if it is trip the latch and recover it with a tiny screwdriver or even a needle. If you can't find a replacement back door you can try welding the hook back in place with a low-temperature soldering iron - with the tip perfectly clean and a very steady hand - as long as the door is thermoplastic and not thermosetting. If that doesn't work bend a paperclip or similar to exactly the right shape with the free ends (roughened) long enough to extend into the plastic of the door by 4-5mm., heat the wire and push slowly into the edge of the door. There are many variations of this technique that I've used, all require extremely careful work! Best tip: spend more time thinking than doing. Good luck.
Nov 28, 2009 | Nikon N70 35mm SLR Camera
The battery door hook which is situated on the body is broken. It seems the hook (latch) is molded on the battery compartment (body) How can I fix this. I am fond of this camera and I have the full...
If you have all of the pieces, you can use crazy glue to make the repair, otherwise take your camera to any camera shop where they will have access to whatever broken components need to be replaced. Regards, Joe
Nov 13, 2009 | Olympus Camedia C-5050 Zoom Digital Camera
Battery door latch broke off body of Canan A590
The same thing happened to me this week. I called Canon Canada directly and asked to order the part (The battery compartment door). They gave me a phone number to call and I was able to order the replacement door for about $8.00 + $10-$12 shipping. Hope this helps!
Jul 10, 2009 | Canon PowerShot A590 IS Digital Camera
Nikon Cool Pix 7900 Battery door won't stay closes
There are plastic clips on the battery door and body of the camera that lock the door in place. If they are broken of the battery door the door can be changed. If the clips on the body are broken the camera as a rule is history. Replacing a camera body is not a feasible repair.
Jul 02, 2009 | Cameras
Battery door doesn't close tight
Usually part of the plastic battery door breaks off so the sliding latch (when you push the battery door in toward the camera after replacing batteries) can't latch. If this is the problem you can buy a new battery door that will come with a new latch that isn't broken.
Jul 10, 2008 | Cameras
Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Oct 15, 2007 | Nikon Coolpix 3200 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
994 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
