Question about HP Compaq FP 7317 17" Flat Panel LCD Monitor
Monitor is black and when I hit the menu button it displays "going to sleep"
  • 4,281 Answers
Power up the computer then check num lock led on keyboard when you press num lock key if its led show on and off then your cpu gives display to monitor then make sure vga cable from monitor from monitor to cpu is attched properly to cpu.
Then when you power up the computer press F8 key then enter in "enable vga mode " then go to display property set screen resolution to 10248768 then apply and ok.
But if num lock key is contstant and it not gives display when you press F8 then you need to open cpu cabinet then reattch the RAM memory then pull cmos cell from motherboard for 10 minuntes then remove pci cards if any.
If you have vga card then reattch in to motherboard.
make sure motherboard is not gorund with cabienet.
If you seen any display like boot post bios screen then make sure harddrive is recognized in bios.
When you power up the computer press F1 or F2 or 'del" key to enter in bios.Reattch both connection to harddrive then check.
Let me know if you need further assistance.
Thanks for using Fixya.
Posted on Feb 04, 2010
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
I have hp w1907 computer monitor. After window startup my screen go black, the monitor light is blue, so it's on. If I press the the monitor button off then back on.....the screen will show for a second...
x2 test monitor on other pc.
if its ok we fix pC>
if the pc drops the sync lines H/V the monitor goes to sleep mode.
and tells you that.
the old monitors 2004 have timer inside,
does the OSD menu button on front of monitor work
with PC on,? it must.
OSD = on screed display from monitor brain
if yes, makes sure any menu there has the sleep timer off.
if it has it.
this monitor is old older than 2010. and has CCFL backlamps then and older.
so use flash light to see if data is on the screen if yes.
then the CCFL tubes are bad or the HV card inside dead.
yup your your service manaual
advanced OSD page clearly show the power saver clock
turn it off now.
of you cant get the OSD to work find a good PC
plug it in and turn this off below.
sevice manual google is your friend, sometimes.
Sep 11, 2017 | HP f1905 19" Flat Panel LCD Monitor
My Dell monitor goes to sleep right after windows xp starts to load and it won't come on after that. my computer is still running but the monitor is a sleep. I have hit f8 and f12 with nothing happening....
Go into safe mode
Under settings, control panel, power options set "turn off monitor to never
reboot
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings
to 640x480
OR
in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
Oct 13, 2010 | Dell XPS 410 PC Desktop
Montior goes black i turn off the monitor and turn it back on i can do about 2 things and screen goes black again repeat this as many times as i want. Gateway FHX2300 monitor
My monitor has been switching connections on me randomly. Hit the menu button. The one to the left of the power butter when facing the screen. Hit the left arrow twice then hit the menu button again. This will open up the screen where you can choose one of three inputs. I'm going to assume that it is on the incorrect input so use the arrow keys highlight what input you are using and the hit menu button again and your screen should return to normal. Mine only does this randomly when it goes into screen saver, hibernate or sleep. I don't know how to permanently get it to stop doing it though.
Aug 23, 2010 | Gateway FHX2300 LCD TV
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
Jun 17, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Sleep mode
Does the monitor go to sleep when you unplug the video cable? If so, then the computer is still sending a signal, if not, check the monitor menu settings for no signal settings.
Apr 25, 2008 | ViewSonic VX2435wm (Silver, Black) Monitor
Blinking lights when PC is s.down
Not sure what happened as I had a whole message typed and lost it. Here I go again. I hope it doesn't post twice.
We have an Acer AL1715 monitor which started having this problem after a power surge. It was the only piece of equipment affected by the surge. I searched for an answer when it happened but got nowhere. I contacted Acer about this and they told me I would have to bring it to a tech to be looked at. Decided on a whim today to try Googling again and found this website and Q&As.
Though we didn't know what "Brunin" was nor saw an "F" change color, we did get into the Menu on the monitor and used the right and left arrows to see what was there. We decided to use "Reset" by highlighting it and pressing the "Menu" button for "Enter".
This appears to have solved the problem for us. The monitor is no longer toggling colored screens when idle nor when the computer is off.
Thank you for solving our problem. It has been very annoying for the user and anyone sitting across from her monitor during a meeting.
Dec 08, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
HP Compaq FP 7317 17" Flat Panel LCD Monitor Logo
55 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
