Question about Hotpoint Ultima WF860 Front Load Washer
Error Code F-05
My Hotpoint Ultima washine machine has just been moved and placed in my daughters new house. On testing it, it fills up, runs the cycle and then comes up with an error code F-05.
Does anyone know what this means? Have I installed it wrongly
  • Hotpoint Master
  • 3,463 Answers
Error code F05 denotes pressure switch jammed on full.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit back and test.
Please rate my solution.
Thgankyou.
Posted on Feb 04, 2010
  • 1 more comment
  • Barry Coates
    Barry Coates Feb 04, 2010
    Furtrher to my post.
    If the washer has just been relocated, then check the outlet hose is not kinked or restricted in any way, also check the outlet the hose is connected to, make sure it is all clear there as well.
  • traceyswift2 Jun 21, 2011
    thank you for the info worked a treat :) x
  • martin peach May 01, 2012
    Hi Barry, I have also tried this and the same things happens F-05, any ideas, thanks.
E05 error on hotpoint ultima wasing machine
E05 indicates that the pressure switch is stuck on full, this may be that your pump is jammed or blocked. Remove the filter and clean it out, also try to fish around in the tube that leads up to the drum. If this doe snot remedy the fault have it repaired by an engineer or someone whom has a rudamentary understanding of the mechanics of a washine machine.
Hope this helps, thanks for using fixya
Jul 06, 2010 | Hotpoint Ultima WF865 Front Load Washer
F 05
Hello,F05 means that the pump is not getting rid of the water.
You to locate and clean the filter, and or check the pump for a blockage or restriction.
Thanks
May 23, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint machine has filled with water and won't empty error F-05 FLASHING before that all lights were flashing ??
Error F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Fit back and test
Jan 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine showing fault code f-05 and door will not open.
Error code F05 indicates pressure switch jammed on full.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Thankyou.
Jan 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code F-05 showing on my Hotpoint ultima
Error code F02 indicates pressure switch jammed on full.
Remove large black hose from bottom of drum.
Remove hose on to pump and check for blockage or obstruction here as well.
Pleas rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Locate and remove large black hose fastened to drum.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Indesit evolution we 123
Hi.
the error code means that the heater relay is not working.
You will need to call an engineer.
If you call hotpoint, it will cost you over £100-00.
Better to call a independant if you can find a good one.
Nov 19, 2008 | Indesit W 123 Front Load Washer
Washing machine
Could be one of the springs that hold the drum is broken.
Jun 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
857 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
