Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
Excessive compressin hard to start - RTO Spur Sprocket For Stihl 017, 021 Chainsaws
    President:
  • 2,220 Answers
Starter Handle difficult to pull:.
1. Remove the starter cover. Does the starter operate smoothly? If Remove the yes, reinstall the cover and continue with 2, if no repair starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required?
· If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; or running on gasoline containing no 2-cycle oil.
· Remove the spark plug wire and plug. Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
4. The last likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH
Lou
Posted on Feb 05, 2010
Causes for excessive fuel consumption in caterpillar D398 Engine
V12 twin turbo with 2x 6cylinder injector pumps.
Excessive fuel consumption can be ...
fuel leak on to the ground.. Obvious
fuel leak into sump via fuel pump body... Check sump oil
worn piston rings... Grey Smoke
glazed cylinder walls...smoke
burnt valves... Need compressin test
faulty turbo(s)... Sound, check manifold pressures
blocked exhaust line/muffler... Smoke black
faulty thermostat so motor doesn't get up to temperature, what is motor temperature ? ... Smoke black
lack of oil, wrong grade of oil for temperature
scavenge fuel line from injectors blocked or not returning to tank
faulty injector(s) causing poor fuel spray
faulty injector(s) bleeding fuel into cylinders... Smoke black
faulty injector pump balance
faulty injector pump timing
faulty coupling between injector pumps, even can be one 180deg out of timing
bad diesel fuel
Are there mechanical losses in motor load ? Alternator fault ? or gearbox fault prop fault ?
What is the exhaust colour ? Black or grey ?
What are the inlet manifold pressures ?
Using a thermometer ( IR if available ) what are the cylinder head or exhaust manifold temperatures ? This may isolate problem to one or more cylinders.
If you can supply more information I may be able to help track down the problem.
Tony
Apr 02, 2015 | Caterpillar D398 marine engine - 1200 rpm
What is the proper procedure for torquing head bolts on a 1930 model "A" Ford ? I do have the bolt tightening sequence.
high compressin head is 65 regular is 55. i prefer to torque each nut to 10lbs first. then torque to spec!
Sep 13, 2014 | Cars & Trucks
Bonneville Problems
enough oil in it. might have blown the engine.get a compressin test done on it
Oct 29, 2013 | Pontiac Cars & Trucks
What has gone wrong?
No compression? You checked this how? With no compressin, this means there is no closure going on in the engine. You might have a broken valve (s); a hole in the piston; blown head gasket; or other problem; or a combination of problems. If there is NO compression, I would start by emoving the heads and having a look. It may not be economical to fix, rather, if this requires engine tear down, you might want to replace the engine or the entire machine.
May 28, 2013 | Kinroad Motorcycles
I have an estate 2005 20hp ohv I/c v-twin model number 13AG618G706. It starts and runs fine until I Engage the blades. Once I do that it'll run fine at a really slow pace. If I hardly press on the...
carb carb carb rebuild rebuild rebuild but as always check spark and compressin on both sides if you only have spark on one side it will sound fine untill under load
Jul 12, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Ok so i got an 04 ninja 250 that will start aslong as i hold the start button to start it but when i let off the button it stops what could it be and how do i fix it and get it started and running any help
open the air fuel screws, yes both of them one quarter turn counter clockwise, and adjust yer idle speed about a turn clockwise,if this does'nt help , check the compressin of each cylinder..
Jun 08, 2012 | kawasaki Motorcycles
What causes oil to enter carb and air breather
crank case has too much blow-by(ring problem) or pcv system is clogged. Most likely ring problem. Check compressin and do cyl. leak test
Jan 29, 2012 | Measuring Tools & Sensors
Engine is not getting started
try a bit of easy start if it trys 2 start if it does i would a compressin test would next step
Apr 16, 2010 | 2008 Isuzu i-Series
On a 2007 Harley FXSTC 110ci my compression droped after fresh rebuild. the way it acted was that it was hard to start up until it seemed like it shot a punch of air out of the airbreather. I believe its...
Automatic compressin releases are connected to the starter circuit. As long as you hold the starter button down the compression releases will be open. Check the push rod adjustment if they are too tight it will cause the symptoms your discribing.
Apr 14, 2010 | Harley Davidson FXSTB Night Train...
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
116 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
