Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Hi just put a ricoh 1515mf on the network but it just prints out lots of pages of rubbish help
  • 62 Answers
Sounds like the wrong driver. Get the PCL5 driver for your model model from ricoh-usa.com. In a pinch use the HP 4 driver, it will get you basic printing.
Posted on Feb 06, 2010
When I try to print anything all I get is a mass of rubbish (5 to 15 pages long). I have driver disc installed but no luck
If the connection to your computer is made by an parallel cable (the connector width is about 2 inches), try to unplug then plug again the connectors at both ends of the cable. An parallel cable that is unplugged partially can generate such problems, because he can't transmit all the 8 bits of information.
If this isn't working, try to connect the printer to another computer, install the drivers and check the printing.
Also, try to replace the cable between the computer and the printer.
Aug 03, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
My machine keeps printing pages and pages of printed pages and won't stop no matter what I do.
If it is printing a print job, press the Printer function button and then choose Reset Job. That will cancel out the print job.
Jan 30, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
Aficio 1515MF All-In-One Laser Printer: I don't know where to find my IP address on my 151...
If you're at the copier, go into User Tools, and then under System Settings there should be a Network section, and then in that Network section you should be able to find the IP address.
You can also print out a config page by going into User Tools and then Printer Settings, and selecting List/Test Print. The config page will have all of your network settings, including IP address.
If you're running Windows Vista and the 1515 is hooked up to your computer, you can view the IP address by hovering over the copier on the Network Map (from the Network and Sharing Center).
May 17, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Can't print color or use finisher on our network ricoh from Mac
Sounds like you may not have the correct driver installed and also not configured right for devices
Dec 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
HOW TO REBOOT RICOH AFICIO 1515MF??
need to enter service programs print out 5990-2
then exe 5801 memory all clear
put all the settings back to where the were set
the printout will show you default and current settings
Nov 10, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
How to set up a page size on ricoh mp161spf.
Under original size ( in printer propertys) select 8 1/2 by 11 -Carl
Jul 21, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I'm trying to print on a Ricoh 1035 from a Mac. Is this possible if it's on a network?
Its possable to print to a networked ricoh 1035 from a Mac... You need the Postscript option...
Jul 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Problems with Mac 10.5.7 Installation
what program are you trying to print from on the Mac? I ran into a similar problem with Quark. here's that solution:
went through some Quark forums on line and read everything about printing problems with Quark 7 or 7.3. Most posts blamed the printer or the driver. However, the common theme was that it was only Quark and not earlier versions.the CUPS filter solution is no helpIn QuarkXPress, you can choose a data format to specify how the data for the pictures in your layout are sent to a PostScript printer: Binary, ASCII, or Clean 8-bit. Because binary data may be incorrectly interpreted through certain network printing protocols, or because your specific PostScript printer may not be able to interpret Binary data, you may need to change the data encoding method from Binary to either ASCII or Clean 8-bit. Please see the More Information section of this article for a detailed discussion of how these encoding methods differ.
Solution: Go to File > Print and select the Pictures pane. In the Data field of the Pictures pane, select either ASCII or Clean 8-bit.
Jun 02, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Printing error log
reset the print jobs then check the printing refeperences.
Feb 08, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
329 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
