How to change IP of Thomson TG585 V7 (192.168.1.254)
Yes you can change it !!! check this speed touch site: http://www.speedtouch.net.nz/500ChangeIPaddress_v4.3.htm
Posted on Aug 25, 2010
    Problem Solver:
  • 16 Answers
This is what I always use and no problems so far http://howtohacklife101.blogspot.com/2012/01/how-to-change-your-ip-address.html
Posted on Feb 01, 2012
  • 12,061 Answers
You can't it is factory set.
Posted on Feb 04, 2010
I am using a Thomson TG582 v 7. I need to change my router password
its because another user are available my network. I want 2 secure for another party to be using my router connections.
pls need your assistance & how 2 change the router password again.
thanks & regards
Posted on Dec 14, 2011
Reset it to drefault, username is Administrator and password is serial of router. then change the ip in there. its easy
Posted on Apr 21, 2010
  • Allan Smith Nov 14, 2013
    i have a link on b2bltd.co.uk that describes this in full
2 Suggested Answers
mikeywaf
  • 346 Answers
SOURCE: Hello, i setup a IP cam.
Hi Sten -- There are several non-intuitive things you have to setup with any router and Dyndns to make this work.
On Dyndns you can setup your static or hardly every changing dynamic Internet (external - provided by your ISP) IP address in your Dyndns account settings (Not the internal NAT IP - 192.168.x.x address of the cam). if it changes more often you need a dyndns client.
On the router you have to setup port forwarding to the internal (NAT address ex:192.168.x.x) address of the camera including the port number -- or you could just create a DMZ (feature of many but not all routers) for the internal IP of the cam.
If you've done the above correctly you might want to check the troubleshooting sections at Dyndns.org located HERE and HERE.
Happy Networking and Thanks for using Fix Ya.
Mikeywaf
Posted on Apr 15, 2011
How can i put a password for my router ? its Thomson TG585 v8
To setup security on the wireless router Thomson TG585 v8 please follow the below steps:
1.Open your web browser.
2 Browse to http://dsldevice.lan or to the IP address of your Thomson Gateway (by default: 192.168.1.254).
3 If you have protected your Thomson Gateway with a user name and password, the Thomson Gateway
will prompt you to enter these. Enter your user name and password and click OK.
4 The Thomson Gateway GUI appears.
5 On the left menu, click Home Network.Under Wireless, click your access point.
Your access point is listed in the following format: "WLAN: ()". For
example, WLAN: Thomson83C7C7 (54Mbps).
6 The Wireless Access Point page appears.In the Navigation bar, click Configure.
7 Under Security, Select Use WPA-PSK Encryption.In the WPA-PSK Encryption Key box, type a the key of your choice. The key must be in one of the following formats:
a. 8 to 63 alphanumeric characters. For example: MyKey123 OR
b. 8 to 64 hexadecimal characters (characters from 0 to 9 and from A to F). For example: C54F48A5.
Click Apply.
8 Configure your wireless client(s) with the same settings.
Please revert back for any more issues that you may face.
Regards
Anand
Apr 27, 2011 | Computers & Internet
Hi, I can't open the main modem configuration page. the modem is (thomson tg585 v8. and the page adress is 192.168.1.254 it opens for a minut or so after turning it off then on, then it shows explorer...
Please try one of the following option:
If your computer runs Windows Vista or Windows XP, you can also access the Thomson Gateway Web Interface using the Internet Gateway Device icon.
If you computer runs Windows Vista:
1 On the Windows Start menu, click Network.
2 The Network window appears:
3 Right-click your Thomson Gateway (displayed as THOMSON TGXXX) and click View device web page.
4 The Thomson Gateway Web Interface appears.
If you computer runs Windows XP:
1 Go to My Network Places.
2 The My Network Places window appears:
3 Double-click your Thomson Gateway (displayed as THOMSON TGXXX).
Be sure you don't have any popup blocker or firewall interfering.
For more reference here below the manual (Version 7 that is basically the same of V8)
http://www.cytauk.com/cytauk/userfiles/TG585-v7_SetupUserGuide_en_pdf.pdf
regards
Mar 22, 2011 | Computers & Internet
How i can re-set factory default for Thomson TG585. i can't set up a user id and password for my net connection.
You can reset Thomson TG585 by pressing the reset button located at the back of the modem for few seconds while the modem is power on. The LEDs at the front would blink and the modem will restart with factory defaults setting.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 24, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
I need to change the wireless channel on my Thomson TG585 V7 and I have no idea how to do this! HELP I'm a complete novice. It is because my DSi is having problems communicating with the router. I have...
If this window does not appear browse to http://dsldevice.lan or the IP address of your Thomson Gateway (by default: http://192.168.1.254 and click Thomson Gateway on the menu on the left-hand side.
Change the wireless channel
Proceed as follows:
1 Browse to the Thomson Gateway Web Interface.
2 On the left menu, click Home Network.
3 Under Wireless, click your access point.
4 The Wireless Access Point page appears.
5 In the Location bar, click Configure.
6 Under Configuration, select the channel of your choice in the Channel Selection list.
7 Click Apply.
Helps that helps!
Jan 15, 2010 | Computers & Internet
How can i reset my thomson tg585 v7 router as i have bought a new laptop with windows 7 and have forgotten my password???? many thanks.
Good Luck!
CreativeTECH
Nov 08, 2009 | Thomson Computers & Internet
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
Thomson TG585 v7 Resets When Rebooted
once agian reset it then put in proper place you get it or do one thing press reset button after removing the power twice time then put on the power then re-cofigure it sir/madam
Mar 03, 2009 | Computers & Internet
Thomson router TG585
do u do any frimware update for you thomson if you do u have to complete it
Jan 19, 2009 | Computers & Internet
Thomson TG585 v7 malfunction
just one answer frimware filure did you skip or try to frimware you self with lan cable
Jan 17, 2009 | Thomson 29DM400 29" TV
Computers & Internet Logo
5,271 people viewed this question
David Payne
David Payne
