Replace Keyboard Sony Vaio CS-Series Laptop - Computers & Internet
    President:
  • 4,070 Answers
Good day.. you may need to see a computer technician to replace your keyboard for there are fragile parts that you may not notice. hope this helps, have a nice day
Posted on Feb 04, 2010
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
Function key doesnt work
The laptop keyboard will need to be replaced, go to www.ebay.com Type: make and model of laptop, refine search to keyboard.
May 21, 2012 | Sony VAIO SZ Series Notebook VGN-SZ780EB
Some of the letters in the keyboard of my daughter's sony vaio Y series laptop won't function. what should i do?
My guess is that either food or liquid has gotten into the keys causing them not to work. You can try the following:
1) Power the laptop off. Now, cradle the laptop with the screen open in one hand. Carefully flip it over. Now, with the palm of the other hand, lightly bang on the keyboard. This MAY cause any food thats lodged under a key or two to loosen and fall out. Don't get carried away with the banging. Just a couple of good taps all over the keyboard should work, if its going to. When completed, roll the laptop over and power it back up. See if your problem is fixed. If not solved,
2) Ok, you've got a more serious problem. This will likely require the replacement of the keyboard. If the laptop is older and you don't want the trouble or cost of replacing the laptop, you can usually just purchase a USB keyboard. Plug it into a USB port on the laptop and your problem should be solved.
3) If however the laptop is fairly new, and you want to replace the keyboard, you can either do it yourself (really NOT a huge project) or bring it in and have someone do it for you. If you opt to try to do it yourself, here is a link to a site with step by step instructions to remove the keyboard:
http://www.insidemylaptop.com/take-apart-sony-vaio-vpcf1-laptop-replace-lcd-screen/
Its not exactly your model, but should be pretty close. Once you get it off, you can then Google 'laptop keyboards' and you'll find dozens of places that will ship you a replacement keyboard in a couple of days. Then just reverse the process to remove it and she should be all set.
No more eating or drinking over the laptop! :-)
Hope this helps!
Jun 21, 2011 | Sony VAIO Y Series Notebook VPCY118GXBI
Hello i have an sony vaio VGN CS14G/B series laptop and i locked my bios .afterall i fogot my bios password .now i am un able to get into bios .so pls help me ......pls
To reset the BIOS password read the information from this link.
In case of your Sony VAIO laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Oct 16, 2010 | Sony VAIO CS VGN-CS220J/T Notebook
Hot to replace
Sounds like the keyboard is bad and would need to be replaced. Laptop keyboards are very sensitive and any dirt or liguid will destroy them. Get it replaced.
May 06, 2010 | Sony VAIO PCG-SR Series Laptop...
Turns off automatically
check your cooling fan sounds like its getting too hot
Oct 03, 2009 | Sony VAIO VGN-CS220J/W Notebook
SATA DRIVER SONY VAIO VGN CS23G_W
Drivers for the VAIO can be found here:
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER
  1. Under option 2 select Computers - Notebook
  2. Click Continue
  3. Either use Option 1 to auto detect your laptop or use option 3 and select the series (VGN-CS)
  4. For model find the full model number
  5. Click Continue
The next screen will have all the relevant drivers for your laptop.
Mar 13, 2009 | Sony VAIO VGN-CS215J/W Notebook
Replace keyboard
you can change your keyboard but i don't recommend it unless you are an expert at doing it. because if your not an expert you will almost certainly damage your notebook.
Mar 01, 2009 | Sony Laptop Keyboard 1-477-006-21 for VAIO...
Drivers for keyboard funtionof Sony VAIO PCG-GR300P
You can try using and typing :" driver VAIO PCG-GR300P " ( ex: using : google search ) there is many alternative web to dowlnload driver for you
Jan 30, 2009 | Sony Laptop Keyboard 1-477-006-21 for VAIO...
Computers & Internet Logo
David Payne
David Payne
