Question about Air Tools & Compressors
How to clean, repair, or adjust a pressure switch that does not turn off at 125psi
    Champion:
  • 243 Answers
Check little hole in regulator where it detects airpressure. check membrane, check electrical part of regulator. but first release screw or bolt to set pressure. this is mostly in the spring.
Posted on Feb 07, 2010
Pressure switch shut-off set too high.
It is adjustable. Remove the square cover nut and adjust the spring tension. . It would be best to lower to 110-115 psi. The compression rings will thank you for it..
Aug 24, 2014 | Campbell Hausfeld CW210500SJ Pressure...
I have a cap2060 Bostitch pancake. When pressure builds to 125psi the pressure switch blows open and starts to release air. I replaced the switch and the same thing is happening. Is there a way to adjust...
A little suggestion as most compressors are build up similar in the same way if your Pressure relief valve (unloader valve) will start continues blow off until all pressure is lost , it has nothing to do with the pressostat switch in most case there is a problem with the checkvalve on the tank sometimes there are metal little oxidized parts coming out from the cilinder like the pressure hose connections Oxidized couplings or membrane you can open and inspect the spring and rubber valve iside the checkvalve clean it from corrosion and metal parts.
AB 9048053 Check Valve
Dec 06, 2013 | Stanley NEW Bostitch 2 HP 6 Gallon...
Load and unload issues
  • The 10 deg pressure band you are asking for is too narrow for the pressure switch. You are going to have to choose to have it kick off at a higher pressure or turn on at a lower pressure.
  • You could install a more precise pressure switch.
  • What are you doing that you set a 10 deg pressure band ?
Nov 12, 2013 | Air Tools & Compressors
Pressure drops significantly before compressor starts
Some pressure switches can be adjusted with an allen wrench. You can't get more pressure from the regulator knob of the pressure isn't in the tank. look at the pressure switch with the cover off. If you see a screw with a spring around it. turn it clock wise 1/4 turn at a time until 125 is reached. The motor will labor more, so 2 hp may not be enough.
May 15, 2013 | Makita MAC700 2.0 HP Air Compressor
Pressure asdjustment
open pressure switch an dunscrew main screw/nut inside tthis will reduce the tension on the spring inside and will cause it to cut out earlier
May 06, 2013 | Ingersoll Rand TS4N5 Ir Electric...
Adjust cw210500sj
My CW210500SJ is rated to shut the compressor off at 125psi but it shuts off at 140psi. Did you resolve your question?
Sep 08, 2012 | Campbell Hausfeld CW210500SJ Pressure...
My husky air compressor is suppose to shut off at at 125psi
Pressure switch may be stuck. May need to adjust pressure switch.
May 27, 2010 | Air Tools & Compressors
Husky 17gal 5hp compressor will not cut off when it builds up pressure. Pressure valve will pop open and then I cut it off buy hand
bad pressure switch or it is wired incorrectly replace switch and check the wiring or could be out of adjustment you compressor is made for max 125psi should be a screw to adjust on the pressure switch near where the wires are connected back out counter clockwise to lower and see if that turns it off
Feb 20, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
107 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
