Dell monitor has stopped working.
My dell monitor has stopped working. The power button is green but nothing appears on the screen. I have checked all the cables.
    President:
  • 4,070 Answers
Good day, i think you have no problem with the monitor, you may have a video card problem. have it replaced and you'll have your computer running back to normal again. hope this helps, have a nice day
Posted on Feb 04, 2010
Dell ST2210 suddenly will not power on. Tried different power cord, outlet, unplugging everything but the power cord and still nothing.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Dell Computers & Internet
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell Dimension 3100 won't start.
Check to see if the monitor cable is connected properly.
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell E228WFP two months out of warranty -monitor on and off
if your purchase just the monitor on 2/28/200, normally dell gives 3 years warranty for the monitor If purchased Separately.
OK.. try doing this call Dell.. 18004563355.. JUST give them the serial number of the monitor ONLY they'll check it out then if your lucky they'll send you a replacement.
Apr 23, 2009 | Dell E228WFP LCD Monitor
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Dell monitor not working
just try running the Test on the monitor(monitor self test) ie disconnecting the video cable of the monitor & leaving the power cable connected & then see if u r getting the red,blue,green multicoloured bard moving on the screen or not,if yes then the monitor is fine otherwise the monitor is bad.
Apr 02, 2009 | Dell Dimension 8400 PC Desktop
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
