Question about Microsoft Windows XP Professional for PC
Corrupted acpi. error 32768 at line 5964 ind. Windows rootsystem32hal.dll.
  • 214 Answers
YOU NEED TO INSTALL WINDOW AGAIN
Posted on Feb 04, 2010
El archivo ACPI.SYS ha causado un error inesperado 32768 en la linea 5964
reinicia a "safe mode" y seleciona el ultimo conocido incio bueno.
Nov 08, 2010 | Acer Aspire 3680 Laptop
Error loading zsqiupzq.dll
Go to Run-->msconfig then see under Startup Uncheck the file showing zsqiupzq.dll file..
**Don't forget to rate and give a positive testemonial...If you find my solution helpful**
Have a Nice Day
Oct 10, 2010 | Microsoft Windows XP Professional SP2
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Computer does not find segate st3120026a. My computer was running fine although slowly so I thought a reboot would help. Upon booting up I got the error:corrupt or missing file: rootsystem32hal.dll but...
Hmmm well thats not good... usually that error is telling you that there is a file that has become corrupted.. or that part of the hard drive is, to me it sounds like the latter... seems to me as if your drive has gone south. Perhaps that was the reason for it being "Slow" .. You could try to recover it? but first I think it would be best to test the disk. They are pretty easy to replace ... You are going to need your Windows CD/DVD. Run the setup through and windows will test your drive for suitability, it is real "picky" so it will tell if it's OK or not.
Feb 02, 2010 | Seagate (ST3120026A-RK) 120 GB Hard Drive
Help on reformating pc!!!
Use different CD installer or burn your present WindowsXP to another disc. Your files might have been corrupted due to poor disk surface of your Windows Installer.
Jan 21, 2010 | Acer Aspire T310 PC Desktop
MY pc does not start anymore. I have a Seagate hard drive ST380011A. I got the message: The following fail is missingC:/windows rootsystem32hal.dll
<windows root>system32hal.dll. is missing or corrupt. â How to fix it?â The Hal.dll file is the first file that boot.ini tells the system to look for at boot. â Looking at it this way, this error message can be rather misleading. In fact the reason could be a number of things, such as: â The boot.ini file is actually corrupt or damaged, â or it is pointing the Startup to look in the wrong place. The Hal.dll file is located in the System32 directory of your %SystemRoot% which in a default XP setup is:â C:WindowsSystem32.â You can use the Dos boot disk (or NTFS Reader above) to quickly determine if the file is missing.â If it is, then you should extract it from your XP CDrom and place it in its proper location.Boot to your XP CDrom, and then choose 'r' to go to the Recovery Console.â With your XP Cdrom in the drive, issue this command:Expand D:i386hal.dl_ C:Windowssystem32â â (This assumes the CDrom is D and your System Partition is C) â If this does not cure your issue this may be due to issues in your boot.ini file.â â The boot.ini file is actually corrupt or damaged, or it is pointing the Startup to look in the wrong place. Resolution:â The easiest way to fix this is to boot to the Recovery Console and replace the old boot.ini with a new one.â Once you have booted to the Recovery Console run these commands at the prompt:Attrib -H -R -S C:boot.iniâ â â (This removes the attributes and allows deletion). DEL C:boot.iniâ â â â â â â â â â â â â â â â â â (Deletes the corrupted boot.ini file)â â â â â â â â â â â â â â â â â â â â â â â â â â â â BootCfg /Rebuildâ â â â â â â â â â â â â â â â (Recreates the new boot.ini file)If you would like to view the boot.ini file, you will need a boot disk to get to the DOS prompt.â If you have formatted with FAT32, then you may use a Windows boot disk (such as a W98 disk), but if you are running NTFS, you will need a NTFS reader boot disk, such as NTFS Reader For DOS which is available for download here.â To diagnose the problem, copy the boot.ini file from the hard drive (C:boot.ini) and open it with Notepad.â You will want to verify that the "Default=" line as well as the ARC path line are pointing to the right location.â Here is two examples of boot.ini files (ARC paths start with multi): [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Professional" /fastdetect This is a sample of the above Boot.ini file after adding another partition running Windows 2000 Professional. [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS [operating systems] multi(0)disk(1)rdisk(0)partition(1)WINDOWS="Windows XP Professional" /fastdetect multi(0)disk(0)rdisk(0)partition(2)WINNT="Windows 2000 Professional" /fastdetect â â
Nov 20, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Having problems with windows rootsystem32hal.dll. what the big problem is i dont know if it came with windows xp home edition or if you can reinstall bujt using f12 or do i need a cd?
One of the key design features of Windows is that it supports multiple hardware platforms without the need for complete different versions of the OS. This support is accomplished through the Hardware Abstraction Layer(hal.dll)
You can extract the hal.dll from your Windows Xp Installation CD to the System32 folder through the recover console.
Sep 25, 2009 | Dell Dimension E521 PC Desktop
Shell32.dll
Try running RUN and type regsvr32.exe /i shell32.dll.
This actually fixes the shell32.dll and installs it again.
RegSvr32.exe has the following command-line options:
Regsvr32 [/u] [/n] [/i[:cmdline]] dllname
/u - Unregister server
/i - Call DllInstall passing it optional [cmdline] (/i /u calls dll uninstall)
/n - do not call DllRegisterServer (must be used with /i)
/s  Silent (added with Windows XP and Windows Vista)
Aug 20, 2008 | Microsoft Windows 98 for PC
Microsoft Windows XP Professional for PC Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
