Question about Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
Scotsman EC 105 - Bin full!
I have a scotman ec 105 ice maker which has stopped producing ice because the "bin full" light keeps coming on even though there is no ice in the machine! I have cleaned the sensors, but still no joy. Can you offer any help?
Regards
Douglas
  • 1 more comment
  • Anonymous Mar 13, 2014
    how to clean out chemicals in tubing
  • Anonymous Mar 15, 2014
    Ice machine shuts down safety limit 1. I just finished cleaning the ice maker and it shuts down just before the tray of ice is released. As I toggle off and on again the ice will then fall.
  • Anonymous Mar 29, 2014
    Machine dumps every 14 minutes but does not freeze completely. Machine has to continue to make ice even when bin is full because it is not frozen good enough and is melting down.
Change the sensor ................
Posted on May 14, 2008
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 107 Answers
Unplug 4from controller if light stays on the control module is bad if it goes off replace the two sensor eyes.
Posted on Apr 18, 2012
    New Friend:
I have the same problem. And I replace the stacking sensor. It was giving me (bin full) now is working fine
Posted on Dec 20, 2012
  • Fred Assally
    Fred Assally Nov 29, 2013
    Not my problem.Mine quits making ice or the ice melts before it will fill up.Never fills up.
  • Luis medina
    Luis medina Nov 04, 2014
    We're its the stacking sensor located
Electrolux ice maker won't stop making ice
The bin full detector is not working--replace it.
May 21, 2014 | Electrolux 15 Under-Counter Ice Maker...
How do i get a service manual?
The bin sensor eyes need to be cleaned or replaced. First remove the front cover then remove the white plastic ice deflector shield. Now you should be looking at the evaporator plate look down you will see the water sump tray full of water in that tray is a black plastic grate that when the ice is harvested it drops and hits the tray keeping it from falling in sump tray PULL it OUT. now just behind the sump where the ice falls through opening on the left and right sides is where the ice full bin eyes are you can pull them out side ways there is plenty of wire so you can pull them up to where you can clean them with a soft cotton cloth with scotsman cleaner. Now for a manual goggle scotsman service manuals you can get a PDF file.
Apr 28, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
Scotsman cme 1656 bill full stay on after cleaning
Ok did you damage the bin thermostat cap tube? The bin thermostat is what tells the unit the bin is full if so replace it.
Nov 14, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
KUIC15PLTS ice maker keeps making Ice even though it is FULL
The high level sensor can get iced up and stop working. using a hare dryer carefully heat the area that the lensing arm goes into or snap off the front cover of the ice maker and blow warm air in there. raise and loser the arm at the same time. a couple of minutes should do it.
Apr 19, 2011 | Kitchenaid KUIC15PLTS 15 Inch Wide 25lb...
Should a scotsman ice machine automatically stop making ice once the bin is full
Yes, all ice machines have a means of automatic shut down when the bin is full. What is the model number of your machine and your bin?
Dec 16, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R... Logo
1,408 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
