Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Bravia will not come out of standby (after 8+ hours) has to be un plugged. Then its OK until next prolonged standby (overnight).
  • 148 Answers
Hi there, First off imediatly place a fan as close to the back of the tv as possible. Your tv's powerboard is overheating, placing a fan (regular box fan orso will do) there will help cool the circuit boards in the tv down. This could prolong the tv's life for a while if yo'r in luck (I have a 32" lcd Poloroid that shut off every 3 minutes orso, on 'lifesupport' this way, its working great(Ibuy and repair these, so I'll get to it when I find some spare time). If yours does completely breakdown (wont come on at all), BUT the powerlight is on, then this fix will still work, once the tv goes out and the powerlight DOES NOT light up or blink, the problem is more trickier (for me anyway), ok, here it goes;The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! Please let me know how this went and if this helped (or not) then please rate, thank you!bravia will not come out of standby (after 8+ - ec15915.jpg
Posted on Feb 04, 2010
The car do not start when it has been off for a long time like overnight...when it does it is with a lot of problems until the engine is really warm. when it hits up the problem disappears until the next...
hi,, check the fuel pump,or better still add an electric fuel pump assuming ur car is a 1.3 king and not the mpfi. further still check the carb and timing, spark plugs. also depress the accelerator couple of times before u turn the ignition and also depress the clutch pedal while starting ur gypsy.
Dec 30, 2010 | 1994 Suzuki Samurai
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
Whenever I turn my sony KDL40V3000 on it
Power supply problems. check SMPs and other feed back voltage signals.
Apr 05, 2010 | Sony BRAVIA KDL-40V3000 Television
Sony kdl 32w4000. Works ok for 10-15mins, then there's a buzz through the speakers and it switches off with the standby light flashing 8 times
Please try this TV on an alternative power source. It sounds like it is getting either too much or inconsistent power from the plug it is plugged into. I recommend trying a completely different wall, as often times one wall with multiple plugs will be on the same circuit.
Good Luck.
Jesse Lohse
Jan 06, 2010 | Sony BRAVIA KDL-40V3000 Television
KDL 32S5500 TV When left on standby overnight locks-up, hangs.
There is a Post on the Sony Support site which I hadn't previously found. Basically there is a software bug which has come about apparently due to Freeview transmission changes. In order to stop the the machine locking up disable the 'Automatic System Update' option. A Sony centre will apparently apply a software fix to properly resolve the issue, fine if with warranty period, maybe pricey if not. I will get the fix but haven't yet done so as the workaround of disabling the System Update option works.
Sep 18, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Within seconds of turning my sony bravia it automaticly goes to standby
Check the lamp, if its ok you can contact sony, some of these s2000 series tvs have an extended warranty until 2010. good luck Julio at Millenium tv - (702) 736-1091 milleniumtvsvc@gmail.com
Jul 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Dead set no standby light power ok up to
Could be anything! From a main board to a power supply. I recommend getting service on it from a authorized sony service center. If standby light doesn't appear at all for any given time, then it maybe the power supply.
Jun 23, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
52 inch bravia will not turn on. Power LED goes to Standby LED and "blinks" three times.
Firstly, Unplug tv for at least 4 hours. Better yet overnight. This is what we call a Hard or Master Reset.
This should solve your problem. If it doesn't it may be that the set has a bad transformer (high voltage)
Jan 17, 2009 | Televison & Video
52 inch BRAVIA turns off and I get 3 "blinks" from the Standby LED
Firstly, unplug your television for at least 4 hours. Even better overnight. This is what we call a master or hard reset. It will hopefully fix your problem The tv may be in safety mode for some reason.
If this doesn't work it may be the set has a bad transformer (high voltage)
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
227 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
