My panasonic dvd recorder was working great and then I had trouble with direct tv and now when I want to record something it gives me a copyright problem? HELP!!!
    President:
  • 1,768 Answers
If you are trying to record from the DirecTV Box there may be a copyright code embedded in the boxes firmware so that if a recordable device is detected it will block recording and give an error.
You also might want to check your DVD recorder instructions to see if you have an issue with the recorder itself but the latter issue is what I suspect is occurring.
Posted on Feb 04, 2010
    President:
  • 1,188 Answers
There is nothing wrong with the player or TV. The programs you are attempting to copy are protected by copyright. Therefore the player will not copy them.
I'm sorry but the TV system is so designed that certain premium and pay-per-view programs carry a signal which instruct the player to not copy them. You should not have any problem copying other free programs.
Tip
Having trouble recording TV broadcast to DVD?
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then stop with a copyright error message during some commercial. I rarely got a complete show. Very frustrating!
Solution: Buy some DVD-RAM disks and this machine will become totally reliable. They are hard to find and a little more expensive than +RW or -RW. Because of the copyright programming on this machine only DVD-RAM disks will work in VR (Video Recorder) mode.
on Apr 29, 2009 | LG RC897T DVD Recorder/VCR Combo
Can record on DVD disc will not play on DVD player
Make sure the materials you're trying to record onto the DVD
is not Copyrighted. Try to record a normal TV program onto your
VHS, transfer it to your DVD and then play it. See if that will
work. A VHS movie is usually Copyrighted and Protected by
Macrovision. The picture output can be displayed on a TV set
for viewing but is scrambled black to a DVD Recorder.
Jul 16, 2011 | JVC DR-MV100B DVD Recorder/VCR
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Copyright Message on Panasonic DMR-ES10-S
certain files are decoded w/ copyright protection not all
Aug 13, 2009 | Panasonic DMR-ES10 DVD Recorder
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
I'm having trouble recording Disney VHS to DVD. I get an error message that says cannot record.
I'm not sure if this is the answer, but I have the same unit and in the directions it mentions not being able to record anything from a copyrighted source. I would assume Disney products are copyrighted and might have a feature that prevents these machines from accepting the signal.
Feb 23, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
