Question about Acer Aspire SA20 PC Desktop
Non booting machine
Hi
I have an Acer SA85-F880 desktop that can't boot however the hdd can boot from other desktops, Ive changed the bios setup for the hdd to be the first booting device but still nothing happens
  • Seporo Lentsoane
    Seporo Lentsoane Feb 20, 2008
    Yes I am in an office environment, the unit is no longer under warranty
    Thanks
I've been tryin ur solutions it seems as if the mainboard might be faulty
Thanks again for your help
Posted on Feb 20, 2008
  • 123 Answers
Could be a fault on the motherboard, assuming other desktops means your in an office enviroment with the same type desktops, is the unit still under warrenty?
  • Steve Martyn
    Steve Martyn Feb 20, 2008
    Yould try disconnecting any cards that are not required, also the memory and then power the unit on, You will hear a couple of beeps, this is normal, then, power the unit off by keeping your finger on the power button for about 5-10 seconds.this will reset anything that may be residual in the memory,
    Put a memory stick back in, try power it up, if this still fails, put the other memory stick and remove the first one (assuming you might have two sticks of ram).
    If this works start putting each card back in one by one and see can you find the fault b process of elimination.
    Let me know...
    x-b-m
My etower 600 refuses to find hdd, why,help
Check the settings of the boot device on the BIOS make sure that the HDD is the first one to boot
Jun 11, 2014 | E-Machines etower 600is PC Desktop
Change the f12 boot menu on an acer t180
Press F2 to enter BIOS setup at startup. You can set which devices appear in the list from the boot menu.
http://johnbokma.com/mexit/2007/12/22/acer-aspire-phoenix-bios-boot-screen.jpg
Jan 20, 2013 | Acer Aspire™ T180 PC Desktop
Acer Aspire X3200 - VIRUS - Won't boot or re-install
it seems like the HDD is not getting recognised , try this might help you get into BIOS setup by tapping delete key or f2 when system turns on , load the defaults settings for bios then try loading OS , if you are getting the same error message that means hdd has gone bad or the cable to the hdd is loose
Jun 29, 2010 | Acer Aspire X3200 PC Desktop
OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
May 18, 2010 | Dell OptiPlex GX110 PC Desktop
Installed service pack 3 now stuck in boot loop
did u change the boot sequence in BIOS....
if u made any changes there u need to set it back to boot from hardisk....
i suggest u keep this boot seq...
1st boot CDROM
2nd boot Floppy drive
3rd boot HDD
u can make to boot directly from HDD as 1st boot
but remember to make changes to BIOS everytime you want to boot from CDROM
Dec 14, 2009 | HP Pavilion a1010n (PS563AA) PC Desktop
Acer Aspire M1100 desktop will not boot or respond
sounds like a motherboard or HD problem, If you can try the HD in a different pc to see if it can be recognize, also don't forget to setup you pc to boot the HD first.
Jul 03, 2009 | Acer Computers & Internet
Acer Aspire85 wont boot anything
You need to get into Bios Setup when the pc first starts.
I am not sure but I think the F2 key lets you into Bios Setup
The primary boot device needs to be the Cdrom drive.
The starting order for the pc needs to be set to
1st Cdrom
2nd HDD
You should then be able to install Vista.
Jul 01, 2009 | Computers & Internet
My computer Acer desktop (ASE 700-ED630M) won't boot to windows. Disk boot failure, controller device 00 no device detected. This may have happened after an xp update. How can I change the bios to correct...
Initially check the connectivity of the cable, whether sata/ ide from motherboard to hdd., also do check in the bios., priority of the boot level whether your hdd is selected., in the first or 2nd., and also do check whther your hdd is detecting in the bios., if not your hdd got problem...
Mar 27, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
Compaq evo-d510-boot problem
change the boot sequence in the bios setup into
HDD
CD drive
Usb
Nov 18, 2008 | Compaq Evo D510 Minitower (Open Box)...
Acer Aspire SA85
go into the BIOS, usually by pressing the F9 Key, and change the boot order so that the hard drive is the first thin g on the list.
Feb 19, 2008 | Acer Aspire SA20 PC Desktop
Acer Aspire SA20 PC Desktop Logo
130 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
