Question about Sport & Outdoor - Others
Starts fine just will not rev at all sounds like it is starving for feul or chokeing up with to much feul, I have check spark and it is good. Cleaned plugs but maybe need to pull carbs appart ,just need to know if this is difficult or not
  • adtewright Feb 04, 2010
    Thanks I check plugs again
    President:
  • 2,050 Answers
I would love to know what it is that you are talking about.
Look to see after you run it, what the plug looks like, wet or black is too much fuel, white is not enough fuel. You could have an issue with air intake dirty, or low compression. If timing jumps, this also will effect it. Carburators have a seperate jet for idle, then another for 1/2 throttle and up. The needle works between these.
Posted on Feb 04, 2010
1998 artic cat 500 4x4 starts fine but soon floods gas out the carburater overflow
well sounds like you need to clean air filter if that does not help i would go with your choke is sticking on if its a cable pull one make sure its pushing all the way back on carb check or if it is electronic one i would replace auto choke good luck
May 03, 2014 | Arctic Cat 500 4x4 ATVs
Craftsman trimmer 25cc
Diaphrams can be tricky sometimes...seating can be irritating. If carb disassembled and cleaned out...might have to check adjustments. Make sure screw didn't get loose. I had one do that before when governor broke.
Apr 21, 2014 | Craftsman Convertible 25cc. Gas Line...
What causes a 1998 s10 2.2 to turn over alot before starting
Since spark, gas and air are the basis for an engine running...check for a good, clean spark going to each cylinder, Check the choke for a jammed preheater coil that is not setting the choke properly.
Jan 20, 2013 | GMC K1500 Cars & Trucks
My honda vtx 1300 will not run with choke all the way in but will run with the choke half way in. what is the problem?
If your bike will only run with the choke half way out it's starving for feul. You have a clogged jet. By choking the bike you cut off the air and allow more feul to run through the carb.
Oct 30, 2012 | Honda Motorcycles
Ok, i recently purchased a DTR 125 R 2000 model with running problems The bike will start with the choke on, then die with the choke off, the fuel/air mixture screw was mashed up so i purchased another...
Sounds like a vacuum leak is leaning out the mixture....check the intake between carb and engine for leaks...another source may be tjhe crankcase seals are leaking.
Mar 31, 2011 | 2000 Yamaha DT 125 R
My engine was working fine for about an hour, then started sputtering and finally quit. I re-started and it ran for about 10 min and the same thing happened. I tried again today and the same thing...
Check filter of course but also you might think of doing a carb cleaning also.Sounds like you might have something floating around in the carb, maybe even a little water in your fuel.If its running better in choke mode it's starving for fuel have carb checked and cleaned. Good luck
Nov 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Greetings... My son's crf150f was running rough yesterday [backfiring-wouldn't rev smoothly] with choke in normal "off" position. Setting choke to half choke middle position allowed much smoother...
sometimes they are stubborne,I use stranded electrical wire to send through jets,just make sure when blowing into an orfus that it comes out somewhere hope this helps
Jun 27, 2010 | 2005 Honda CRF 150 F
Yamaha EF1000is, Will no run without choke on
It is starved for fuel. PROBABLY needs to have carbureator cleaned and adjusted OR the fuel filter may be clogged.
Nov 02, 2009 | Yamaha 2500 Watt Industrial Inverter...
3000iseb will start but will not rev up. sits and
check air filter and exhaust for blockages. Sounds like it is choking
Sep 20, 2009 | Electrical Supplies
Ford Focus Deisel chokes on acceleration
Hi mate.
This sounds like a fuel problem.
Some one may have have filled up with petrol. If so you will have to drain the feul tank and change your feul filter.
If only diesel has been put into the tank then carry on as follows until you solve the problem.
Change your fuel filter and air cleaner for a start.
Check your timing.
If you still have the problem, then have your injectors cleaned and reset.
If the problem is still there then you will have to have the fuel pump reconditioned.
You can also check your leak off pipes between the injectors to see if they are in good condition.
I trust this will help you.
Ray
Sep 01, 2009 | 2004 Ford Focus
Sport & Outdoor - Others Logo
23 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
