Question about Dell Inspiron XPS M140 Notebook
The display on my laptop my suddenly developed black lines (about an inch wide) down each side. I have no idea what caused this or how to fix it. Can you please help?
    President:
  • 1,188 Answers
If its not a hardware fault then you have most probably changed the resolution.
To change your screen resolution 1. Open Display in Control Panel. 2. On the Settings tab, under Screen resolution, drag the slider, and then click Apply. 3. When prompted to apply the settings, click OK. Your screen will turn black for a moment. 4. Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Reply back if the lines are still there.
Posted on Feb 04, 2010
How to fix Westinghouse WD32HD1390 tv when black vertical bar show up on display?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 19, 2017 | Westinghouse Televison & Video
Vizio XVT3D650SV 65-Inch Theater 3D Edge Lit Razor LED LCD HDTV has a black vertical 6" wide line on the right side of screen. What is causing this problem? Is it the T-Con board?
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 23, 2016 | Vizio Televison & Video
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
Main power supply regulator board can cause this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 03, 2014 | Televison & Video
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. any Ideas ?
Toshiba Laptop screen has 2 inch black line down the middle?
seems to me like your screen has developed some bad segments and will need to be replaced, you will need to take apart the laptop to remove the screen/display and purchase a new one and replace it,
Feb 20, 2010 | Computers & Internet
Display has 2 inch black stripe running vertically down screen
I have an IBM think pad that developed a 2 inch black strip on the left side of my dispaly. I tried restoring to a previous setting, I updated video drivers, I reset display properties. None of the above worked and am now thinking of formatting and reinstalling windows as a last hope unless someone has any other ideas.
Dec 26, 2008 | Toshiba Satellite P105-S6104 Notebook
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Apr 16, 2008 | Toshiba Satellite P105-S6207 Laptop
Dell Inspiron XPS M140 Notebook Logo
Alun Cox
