Washing machine starts then stops
The washing machine starts on the first part of the cycle then just stops and does nothing ive cleaned out all the water from the filter at the bottom but still not working please help??
  • mjb1 Feb 20, 2008
    so how could i fix that myself do u know thanks
    Problem Solver:
  • 15 Answers
Could be the timer switch which is connected to the motor to start got the problem.
thanks,
2toy
Posted on Feb 20, 2008
  • Ruel Ocampo
    Ruel Ocampo Feb 24, 2008
    if got the background of servicing the unit then perhaps you can do it. but if you have not any experience doing it you should call a repairman to do the job, it kinda complicated to install it.
    you can buy the timer the same as the brand of machine you are using now,t meet the compatibility during the operation.
    thanks
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
Our washing machine smells at the start of a wash cycle and smells of fish.We have done ample clean cycles using different products and washed using various washing powders and liquids etc at 90+c. is...
posibly not melting glue as there not used in making the machine try putting a blech hot water wash cycle a few times in the machine and if the washer is not being used leve the door open to allow the unit to breath and stop using powder wash detergent use liquid wash detergent
best luck
Nov 10, 2010 | Bosch Washing Machines
Beko WMA10 W Washing machine. Power light on but thats it.
sounds like the main bearing,it would be cheaper to puchace a new mc
Jan 05, 2010 | Washing Machines
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
