Question about Samsung Computers & Internet
Turn monitor on stays on for 2 or 3 seconds screen goes blank.
  • carpetdood Feb 04, 2010
    The monitor is doing exactly the same thing when it was connected to the computer. I disconnected it and plugged it into a wall outlet. I turned it on and it stayed on for 2 or 3 seconds then went blank. I'm using another monitor so it can't be my computer. I've never dropped the monitor its never been wet. I bought new 18 months ago. Safe to assume it's a piece of junk? I don't see any reset buttons on the monitor. Its always been plugged into a surge protector. Open to any ideas.
    Forgot to ask how do you adjust to factory settings?
  • 641 Answers
This is a power save mode for when the connector is loose or sometimes the graphics card goes out you also won't be able to see anything on screen.
Posted on Feb 04, 2010
    Novelist:
  • 153 Answers
This is vague, there might be 2 reasons why the monitor stays blank, it's either that the monitor is faulty or the computer tower doesn't POST.
If the problem is with the monitor:
- Disconnect the monitor from the computer tower with the computer turned on, check if you see anything on the screen as a sign that it's working, there's no problem with the monitor (If it's completely blank still)
- Try to reset the monitor to factory default settings
If the problem is with the computer tower
- Disconnect all the connection from the back of the computer tower
- Press the power button of the computer tower for 15 seconds to drain the remaining power
- Reconnect the monitor cable and the power cable then start the computer, (If it turned on, it means that the problem is with one of the devices connected at the back of the computer, all you have to do is to check it one-by-one) (If it didn't turn on the computer)
- Reset the CMOS battery
- Open the computer tower and reseat/remove the video card (VGA or PCI-E or any device in the PCI slot) then turn on the computer (If this didn't fix the problem)
- Reseat/remove the hard drive, then turn on the computer (If this didn't fix the problem)
- Reseat/remove the memory chips. If you have 1 or more memory chips, remove them all and try to test them one-by-one to each slot and turn on the computer (If it didn't resolve the issue).
- Reseat the CPU and turn on the computer
- Reseat the power cord from the power supply to your motherboard and then try to test the computer again.
- If all else fails, the problem might be with the motherboard and the power supply.
(Note: if you see big amount of dust, try to clean it thoroughly)
  • John Espanol Feb 05, 2010
    I'm sure there is a button on the monitor that would give you that option. Try to press each button and navigate through it, I don't know the brand and model of your monitor so I can't give you any exact step-by-stey instructions.
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Aug 19, 2008 | Philips 19 in. CRT Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Screen STAYS BLANK
check your system unit to make sure the problem is not from the system unit
the signal stage and cable is more likely to have faults contact a local technician for confirmation
Nov 27, 2007 | Star Logic 17" LCD Monitor
Computers & Internet Logo
42 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
