Question about RIM BlackBerry Pearl 8100
BB restarts every five minutes. Have tried wiping data and bringing it back to factory settings as also upgrade the software available. But these do not seem to work pl help
  • 2,069 Answers
Perform a "hard reset".
when your BB is on, pop out the battery and leave it out for about 30 seconds, put it back to your BB, your BB should reboot. then check
Regards
Posted on Feb 04, 2010
  • Muzahura Frank Feb 04, 2010
    If your problem persists, please go here, download the BB desktop manager.Use it to format your device and thereafter restore the OS.
    regards
Please I forgot M????????? blackberry password, how can I. Get it back! Pls help
Dear Ella,
Unfortunately you will have to get the BB wiped off by entering the wrong password 10 times. Then it will ask you to enter the word "blackberry" and it will restore the device to factory settings wherein you will lose all your messages and contacts. Assuming you've a backup of your data you can restore it to the phone thru Desktop software or incase you do not have a backup I would advise you to kindly keep backing up your phone in future to avoid such data loss.
Feel free to revert back for any other assistance
Regards
For Fixya
Laxman
Mar 24, 2015 | Blackberry Cell Phones
How can i fix my blackberry 9380 because it keeps restarting itself
This is due to a glitch in the Operating System (phone software)Go to options, Security, Security wipe: Type the word blackberry and click wipe data. You blackberry will be restored to factory settings, meaning the software will be free of bugs. You will then have reinstall your programs again so go to the BB App world and select uninstalled software to see what software you need to reinstall again. Enjoy
Dec 01, 2014 | Blackberry Cell Phones
I am not able to receive calls the next day after charging my Blackberry 9530 storm, then i have to remove the battery and put it back again to receive calls. Any permanent solution for it?
Yes, there is a solution and I hope this also works for you. My 9550 would freeze and I couldn't answer a call, or it will just freeze on it's own at least once or twice a day. I also had to remove the battery then replace it and it will be fine again. After emailing the store where I bought the phone. One of the solutions was to wipe the memory as stated here. (To try to "wipe handheld":
1. In the device Options, click Security.
If you are using BlackBerry Device Software 4.1, click Security Options > General Security.
2. Click the trackwheel and select Wipe Handheld.
3. Click Continue.
4. Type blackberry and All the data on the BlackBerry device is erased.)
Then restart the phone and it should work.
Better yet. If you have the BlackBerry Desktop Software Application on your computer. If you don't go here https://swdownloads.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=A2C0D61EB187AB3AFD247A852FAD3647 It's a 114mb file. Connect your BB with your data usb cable. Then back up the phone and do a software update (Which is what I did). The software will back up your data, then wipe your BB clean. Then it reinstalls the software. The process takes between 30 minutes to one hour to complete. You should be ok after the update. My BB 9550 works fine now since the update four days ago. No more issues.
Jul 09, 2011 | RIM BlackBerry Storm 9530 Smartphone
My nokia E 72 hangsup frequently for no reasons more so when i open text messages . I had to restart to function. I have upgraded with the latest software for this device available for the indian...
Just follow the steps
Make a backup of contacts in your another sim.
Try to Restore factory settings
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3"
"green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory
stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Nokia E72 Smartphone
How can I reset my blackberry curve8520 myself?
The fastest way to reset your BlackBerry Curve 8520 back to factory settings is to peform a security wipe. it will result in the loss of all user data! It is recommended to perform a backup of the BlackBerry 8520 data. .
To reset BlackBerry Curve 8520 to factory settings: Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Hope this helps, if so do rate the solution
Jan 04, 2011 | RIM BlackBerry Curve 8520 Smartphone
Does the recovery feature totally wipe out all saved files and pictures?
As a rule, system recoveries usually bring a PC or laptop back to the factory install, effectively erasing all new data created and stored since its purchase. I would suggest backing up your current files before running the system recovery if it is an option.
Nov 25, 2010 | Toshiba Satellite A100-S8111TD Notebook
I want to bring my laptop back to factory settings
for a dell with windows xp
restart the system and right on the dell logo screen hold down ctrl and tap F11.. as in ctrl+F11
as you see the next page hit restore and it will start and complete in 10 min.
for windows vista_________________
restart and tap F8 a couple of times at dell logo
()choose repair my computer and then login as admin
() select dell factory image restore
careful it will wipe all the data that you you've put after getting the system
Dec 13, 2009 | Computers & Internet
Change the language in a blackberry tour
you need to wipe the device, as in bring it back to factory settings, you will lose all data and contacts on the device.
1. In the device Options, click Security. If you are using BlackBerry Device Software 4.1, click Security Options > General Security.
3. Click Continue.
4. Type blackberry. All the data on the BlackBerry device is erased.
Sep 30, 2009 | RIM BlackBerry? Tour 9630 Smartphone
Will re-setting bb bold to factory settings delete my downloads?
Yes sir! A "Hard Reset" will COMPLETELY reset the all interface back to factory default.
If you use the Blackberry Desktop Software you can easily, back all your data first, then initially "hard reset" the device. After you have performed the necessary steps you can restore all your data.
Hope this helps!
Mar 19, 2009 | RIM BlackBerry Bold Smartphone
No message services configured after wipe and reset
sounds like you need to set up the WaP settings this and address they use so that email and texting can be used
on your phone and most black berry BB use the same wap
for your BB you set the WaP threw security with the tech of your service provider they will give you info on that to set it up
now for the BB there is a setting if you already have the services it states in service provider if you did not set your service code by registering it with in 48 hours even after a wipe you will need to have a new code installed
after 48 hours of a wipe your services are whats the word scrapped and then you have to set services back up threw service provider this will bring back the tzones and browsers
this info is an add info install
in your BB there is a registration button once you click this after your services you know works will register back all info and place appropriate icons back on the face desktop
i hope this helped you
i went threw this not just 2 weeks ago when i upgraded my BB so im fresh on the info im giving you
May 29, 2008 | RIM BlackBerry 7290
RIM BlackBerry  Pearl  8100 Logo
27 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
