Question about HP Photosmart C6100 All-In-One Printer
Printer shows offline
After sharing a network printer , when i try to access that from another machine. it get attched but when i try for printout , it does not get that. and after some time it get offline.
  • Beerm0nster May 11, 2010
    Hi, On the computer that you are sharing the printer can you check the following: 1. That you have IP connectivity between the two PC's Open up a command window on both PC's and type ipconfig to determine the IP address of that machine. On the remote machine's command window type "ping a.b.c.d" (where a.b.c.d is the IP address of the remote PC you determined from the command line). You should see a response if connectivity is good i.e. Pinging 192.168.99.254 with 32 bytes of data: Reply from 192.168.99.254: bytes=32 time=2ms TTL=255 If you have connectivity, it may be that you have a personal firewall on the PC sharing the printer that is blocking the traffic from the remote PC? (i.e. ZoneAlarm etc etc) How close are the PC's? .. would it make sense to use a USB switch to share the printer instead? .. this has the benefit that both PCs dont need to be on at the same time Let me know how you get on and hopefully some of the above will steer us towards a solution!
  • 214 Answers
ATTACH WIRES PROPERLY
Posted on Feb 04, 2010
Always shows "Printer offline" status (Mac OSX)
Have you installed the printer driver for the selected printer??
Oct 30, 2017 | Samsung Clp-325 Colour Laser Printer
The shared printer shows offline. The computer operating as it's printer server is Windows 7 as is the laptop attempting to send jobs to it through the homegroup share. Is this a printer problem or an OS...
check on the server if the shared printer is online. check also on the work station if the printer configured properly as shared. (try to check printer network communication)
Jan 14, 2011 | HP PhotoSmart C3140 All-In-One InkJet...
New printer. HARDLY USED Worked fine when first installed. . Now shows as offline on all five network printers. Ethernet connection. Power is on. Tried rebooting, Checked connections. Is the printer...
1. Try to print from local system if it does not then reinstall printer driver. check catridges.
2. Now right click on the printer using sharing options, share it again.
3. On the other computers using network icon, browse the printer connected system. Explore the system till you see the shared printer and double click it. It will take 2 to 5 Minutes and then your printer is network connected.
4. Now remove the old printer icons. And check printing using the new one.
Sep 11, 2010 | HP OfficeJet Pro K8600 Printer
Printer status reads "printer offline"
Could be several things causing this. You said it is a network printer, but then said primary computer is XP. Is it hooked to the XP machine? From my experience, printers on XP machines occasionally lose their drivers. Go to the XP machine and make sure the printer is in the printer folder, and active. Do a test print to be sure. Then make sure it is still shared (things like this can change with updates). If all this is OK, go to the Vista machine and remove the printer. Then go to add printers, and add a network printer. Sometimes, if it is a network printer, it will show up in "my network" - if so, right click and add printer. If you add the printer usually the computer will use the currently installed drivers. If it is a shared printer, go to network, double click the XP machine, and the shared printer should be there. right click and add. Once you have it working, go to printers and delete or remove the faded-out printers that don't work and be sure to set the newly installed printer as your default.
Sep 06, 2017 | HP OfficeJet 7310 All-In-One InkJet...
Our Ricoh MP 171 devices go offline after one
have you tried doing a local connect using a crossover cable to the printer to see if it is the printer or the 2k3 server?
I have seen this issue when terminal services are enabled on the server.
if when you connect locally to the device using x-over it still does it it may need to have the nib firmware updated, however if it doesnt I would run a packet sniffer on the network jack that the device is plugged into and check to make sure that the port is good and transmitting and receiving all packets check the network cable and replace that and if all else fails try the device on a different network port.
Jul 15, 2009 | Ricoh Office Equipment & Supplies
Cannot print to network printer
Is this printer installed on a server and shared over a network? Or is it installed independently on each workstation?
If it's on a server, printing could be "paused", or set to "use offline" Go to the "printers and Faxes" dialog box, and 'right click" on the printer icon, is there an option to either "resume printing", or "use printer ON line"? If so, select this option.
If it's not on a server then it would be extremely unlikely that this condition would happen on all workstations
Other than that make sure that the Subnet mask is set correctly on the printer.
If that doesn't work....it's probably time to try re-installing the driver.
May 13, 2009 | Kyocera Copystar CS-1820 Black and White...
Printer won't print
You have to turn printer sharing on in vista by going to your network map and turn the printer sharing on. This should FixYa! Network Map is located in Network and Sharing Center on the computer with vista.
Jan 27, 2009 | Dell Inspiron 6400 Notebook
The 8860 printer is showing offline on the network
sounds like you need to open the sharing section of the printer set up, and set it for sharing on the network
Jun 16, 2008 | Brother MFC-8860DN All-In-One Laser...
Network printe on vista
Accessing a Shared Printer To access a shared printer from a computer running Windows Vista, do the following:
  1. Click Start, and then click Network. The Network window displays a list of computers in the workgroup of the computer.
  2. Double-click the name of the computer containing the shared printer that you want to access.
  3. Right-click the shared printer that you want to access, and then click Connect. Alternately, you can double-click on Printers to see just the list of shared printers, and then right-click the shared printer that you want to access, and then click Connect.
After you have connected to the shared printer, you will be able to print to this shared printer as long as the printer and the computer sharing the printer are turned on.
please note that in network the computer that has the network printer if it is running XP may take as long as 15minutes to be recognized.
Apr 09, 2008 | Samsung ML 1610 Laser Printer
HP Photosmart C6100 All-In-One Printer Logo
100 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
