Mitsubishi tv wd62525 status light keep flashing
  • 111 Answers
You have 4 bad caps. on the dm module they are i think 3300 uf at 16 volts im not real shure about the valu its been awhile but they are the only electralictic caps on that module
Posted on Feb 04, 2010
3 Suggested Answers
  • 556 Answers
SOURCE: Mitsubishi WD62525 Dead NO Power-Won't turn on
Don't think dm board will solve your issue, might want to check power board for buldging caps.
Posted on Aug 10, 2009
Slinteriors
  • 8617 Answers
SOURCE: have wd62525 mitsu status light flashes tv wont
The status light flashing usually indicates the lamp cover door or the side air vent door are open or the switchs are not working.
Posted on Mar 17, 2010
Keeps switching inputs
WD82837: Mitsubishi 82" Rear Projection
Problem: The "status" light flashes yellow while no picture display. Nothing happens when pressing the power button. The light keeps flashing if plugged in. I cannot test for codes by holding for 5 seconds as there is no place to check the code problem due to no display. HELP!
Feb 07, 2014 | Mitsubishi WD-82837 82 in. HDTV DLP TV
I have a mitsubishi 62" wd62525, I replaced all
When you unplug the set it then when powered up waits for the DM unit to boot up----the green light blinks on the front for about 70 seconds and when it goes out the set can be turned on.
If this is the case I have a suggestion, let me know if I have described the situation correctly.
SD TECH
Oct 25, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My mitsubishi tv has a blinking green light and tv wont come on. I have tried unplugging, resetting but the light continues to blink. My set is the WD62525 model.
maybe your tv is defective there is parts is shorted it cannot osolate. if you have a mitsubishi service center in your area ask the technician to fix your problem
Jun 19, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Have wd62525 mitsu status light flashes tv wont
Mar 16, 2010 | Televison & Video
I have a mitsubishi wd62525 and it shuts downwith
a code 12 is nothing wrong with the tv,try
playing a dvd to see if the tv shuts down.
Aug 19, 2009 | Televison & Video
Aug 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Error Code 56 and Yellow Status Light
check the error blink code again as 56 is not a valid error code for the WD62525
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Jan 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv turns on and than red status light comes on and shuts down
it sounds like the 3300uf caps on the power supply have gone bad.look at them and see if they are pregnant. if so change them. while you have the shield off see if any other caps are pregnant, if so you might want to think about having the chassis repaired.
Dec 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Timer light will not go off and I cannot turn on TV
ybhughes,
Are you asking about the wd62525? If so that's a v26 chassis and equipped with a self diagnostic test by flashing a series of two digit sequence after depressing the power button. After depressing the power button count the number of flashes - then you'll see a slight pause - then another series of flashes. (for example: four flashes, pause and four more flashes is an error code 44). The unit repeats this coding at least three times so be as accurate as possible...
Bill
Sep 26, 2008 | Televison & Video
Televison & Video Logo
316 people viewed this question
Top Televison & Video Experts
Electro Med Services...
