Question about Insignia IS-LCDTV32 32 in. Television
Screen is blank but can hear all the channels. cable guide shows up but no picture. What do you think the problem is
  • Insignia Master
  • 8,457 Answers
Reboot ur cable box,by unplug,replug the box after awhile.Turn on/off sholud work agian.Not ur tv because u have the cable picture guide show up on ur screen right?
Posted on Feb 07, 2010
    President:
  • 1,768 Answers
The video circuit section of your LCD needs service and this will require board level troubleshooting and by a qualified service tech. There is a light tube or floresent tube that excites the liquid crystals to give visual to the screen and it may have blown and needs replacement.
Posted on Feb 04, 2010
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Black screen
Possible causes
  • Your TV is not receiving or displaying the signal from your DIRECTV® Receiver.
  • Your receiver has correct guide information, but is not processing video correctly.
  • You are viewing a channel where an upcoming sporting or special event is scheduled or has recently ended.
Solutions
  • Turn TV off and on.
  • Make sure light on front panel of receiver is lit.
  • Press the "TV/DSS" button on the remote control or front panel of the receiver (not all receivers have this option).
  • Reset the receiver by unplugging the power cord for 15 seconds.
  • Check all cable connections between the dish, receiver and TV.
If the picture is black, but the program title and description display in a banner the top of the screen:
  • If the problem is only occurring on a few channels, check the detailed description of the program through the on–screen guide on those channels. Often, we display a blank screen with a banner before and after a high–profile event to alert customers about the event.
  • Reset the receiver by turning off and unplugging the power cord for 15 seconds.
  • Run a signal meter test to check your signal strength (press "menu" and look under "setup" or "installation").
If your signal strength is below 70 (or below 60 on HD receivers) in clear weather on transponders 1 and 2, see our troubleshooting steps for "Searching for satellite signal. Please stand by." You may see zero strength on transponders 4, 12, 18, 20, 26 and 28. This is normal in many areas. Your system manual shows how to run cables and point your dish.
Oct 24, 2007 | Toshiba 30HF66 30" TV
Blank, snowy screen,cable box on, tv on, volume control on, wont change channel, just snowy screen
have you check your cable? is it connected to your cable box? have you change the channel vhf to uhf?
Apr 06, 2012 | Televison & Video
My xbox 360 wont show a picture but it has sound
Since your sound works, you know the xbox is booting properly.  Check two things: 1) try another television to make sure it's not the tv.  2) try another cable(from a friend?) to see if the cable is bad.
**Also, if the video settings were saved on an unsupported setting, it could cause the screen to not show video.  If you try these 2 things and you think someone might have saved bad settings, I recall a button combination you can use to reset certain things, and I try to help if it comes to that.
May 30, 2009 | Microsoft Xbox 360 Console
Sony 60in Grand Wega Channel Guide comes up/Screen goes Blank
u may have a bad cable box ( drectv) try a dvd player on the tv if it work fine that means u have a bad cable box ( drectv)
May 08, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Screen blanks out int when on local channels
I had the same problem (a flashing HDMI 1 text box in the upper left hand corner of the screen every +/- 10 seconds) and rebooting the cable box seemed to help. I'd previously tried disconnecting and reconnecting the cables, but wasn't successful. I assume my problem originates with Time Warner Cable.
Jan 29, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Poor screen resolution and unable to get channel guide.
The channel guide is a service just like closed caption. Rumer has it that it's not going to be around for much longer. The only fix is to unplug set ..wait awhile till memory loss occurs...plug back up and do a setup. Nothing in the TV will cause partial guide. Weak signal could and cause fuzzy picture too. Complain to cable company. But brightness problem is something else.
Dec 27, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Sound stays on & picture goes to blank screen
I do not see any reference on this problem and I even checked with Sony. If you are on a cable box, I suspect that is the problem.
Oct 25, 2007 | Sony KP-43T70 43" Rear Projection...
Insignia IS-LCDTV32 32 in. Television Logo
217 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
