Question about Kenwood KDC-W7027 CD Player
Kenwood kdc 7027
When i switch on the ignition the radio never comes on and the flip screen just moves about and then the unit switches off.
  • 1 more comment
  • sparkedout Mar 09, 2008
    I turn the ignition on radio comes on goes off and the screen/panel just moves about. Eventually it comes on sometimes it doesn't.
  • Anonymous Jul 17, 2008
    geting code to stay
  • Patrick1971 Oct 02, 2008
    have you solved this problem. And can you tell me how to get access to the switch on th pictures.
    Greetings,
    Patrick
The home position switch from the angle of the front display is not pushed correctly. the problem is mechanical.
If you glue a little tip of plastic between the actuator and the homeposition switch, your problem is history.
In my case, a tip of a little tiewrap did it.
Posted on Apr 30, 2008
Kenwood kdc 7027. The front panel is floppy and can be moved easily.to get radio on you have to hold fron panel and press on button for a while, some times the panel tries to move about when you do this.... Can it be fixed???
Posted on Mar 18, 2011
I have a kvt 512 kenwood was pushing the unit in and the radio fuse blew installrd a new one now the player doesnt come on u can hear the motor moving in the inside but the reset button keeps blinking red
Posted on Aug 10, 2010
I am having the same problem have glued this piece in and now the white thing has moved further away from the switch and the piece of tie wrap has come off
Posted on Oct 05, 2009
Will try this and let you know! Had the same problem.... weird><
Nice1 POLESGAN
Posted on Sep 11, 2008
So what do i have to do...
Posted on Jun 04, 2008
How can I program the kenwood kdc252u to turn on and off with the ignition? As of now the unit stays on after I turn the vehicle off, or stays off after I turn it on.
you have wires crossed or not hook up ignition switch for radio stereo power wire connects to cars ignition.stereo memory (yellow or orange wire) connects to constant power for radios memory(rad stations /clock)
Feb 26, 2014 | Kenwood KDC-252U
My Kenwood Excelon KDC-X559 does not power on at all. I know that it is getting power though. You can insert and exit cd's from the unit but that is all it will do. Screen does not show power at all. Is it...
are you sure you have power going to the red wire? the red wire needs to be connected to a switched (ignition) power source. the radio will not work unless both the red and yellow wires are getting power.
Mar 06, 2011 | Kenwood eXcelon KDC-X559 CD Player
KDC-4051UG Only comes "ON" with
Your head unit is now connected correctly. That is how it is intended to be installed. Unless it doesn't store the radio stations. In that case the power cables of the head unit (RED&YELLOW) are incorrectly connected, but not a big problem. hope that helps dreamsystems
Feb 06, 2011 | Kenwood Car Audio & Video
KDC-7027 car sterio comes on for a second then moves then goes off again
sound like you have a bad ground. pull the stereo out and check your ground wire go from there.
Jan 11, 2011 | Kenwood KDC-W7027 CD Player
Radio does not turn on, and can not eject cd.
HAVE YOU REPLACED UNIT? IF YOU HAVE THEN IT COULD BE THE SWITCHED / CONSTENT FEED BEING AROUND THE WRONG WAY, YOU CAN TEST TO SEE IF YOU HAVE A CONSTENT FEED WITH IGNITION OFF ON ONE OF THESE, AND A FEED ON THE OTHER YOU TURN IGNITION ON, THE THESE ARE NORMALLY RED AND YELLOW SWAP THEM ROUND, GROUND/EARTH IS BLACK, FUSE N HEAD UNIT NORMALLY BEHIND THE PLUG THAT FITS IN THE HEAD UNIT
Dec 06, 2009 | Kenwood KDC -X815
Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
Nov 21, 2008 | Kenwood KDC-MP235 CD Player
How to put the code in my cd radio
SELECT THE SECURITY DIGITS TO ENTER PRESS THE FM OR AM BUTTONS PRESS THE [[ ]] ARROW SEARCH BUTTONS TO MOVE ALONG AS YOU ENTER YOUR CODE WHEN CODE IS ENTERED PRESS AND HOLD ]] FORWARD SEARCH BUTTON FOR 3 SECONDS RE-ENTER MAY APPEAR REPEAT THE SAME AS ABOVE TO COMFIRM CODE IF NESSARY HOPE THIS HELPS YOU JAKE YOU CAN DOWN LOAD A MANUAL FREE I HAVE ENCLOSED MY MOBILE NO 07936635539
Jun 07, 2008 | Kenwood Car Audio & Video
Kenwood KDC 237
Can't find your unit on Kenwoods site. But try here.
http://kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Good Luck
Leadispenser
Mar 20, 2008 | Kenwood KDC-135 CD Player
KDC-X869 Face Flips Halfway, Unit Turns Off
I have worked on many of these radios and there is a lever that contacts switch to determine position of face this lever wears out and switch does not operate properly causing radio to lose its mind. This is usually the cause of this failure unless flip gears have been damged somehow. contact kstahl65@att.net for additional info
Jan 21, 2008 | Kenwood eXcelon KDC-X879 CD Player
Kdc-x879
it needs a new ribbon cable. Some car audio repair shops stock these (mine does). Part is about $20-30. Labor will depend on the shop.
Sep 20, 2007 | Kenwood eXcelon KDC-X879 CD Player
Kenwood KDC-W7027 CD Player Logo
1,034 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
