Question about Gaggia Titanium Espresso Machine
Beans stick in hopper
Although I'm generally pleased with the Titanium I bought a couple of years ago, I've never been able to fill the hopper with decent espresso beans and not have to keep stirring the beans around, before the 'COFFEE BEANS EMPTY' message appears.
I've tried using lightly roasted beans, and these work ok, if you don't mind a very weak coffee
I have a friend with the older SYNCRONY Digital, and because it uses a straight sided bean holder, works fine with exactly the same beans I like.
Tried contacting Gaggia, but they just recommend using Gaggia beans.
  • jportela Feb 24, 2008
    I need your help please. I have a Gaggia Syncrony compact that will not get past the grind cycle. It did do enough grinding a couple of times and continued to make espresso but eventually the red light #28 comes on steady indicating the coffee bean container is empty but it is in fact full. All web troubleshooting tips were fruitless. I changed coffee bean type three times to a non grease kind and totally (trust me) cleaned out the grinder more than half a dozen times.
    I have taken the machine apart and as best as I can tell the grinder is not pushing the grounds enough. It is a 2003 machine I bought second hand. Could it be the grinding burrs need replacement? I say that because not enough grounds had fallen in the hopper every time but the chute was full of ground coffee and the grinder was also.
    I am at wits end trying to figure this out but would like to fix the machine. Please help.
    Jose Portela
  • Anonymous Mar 31, 2014
    im using coffee beans but the coffee is coming out cold
    Problem Solver:
Bob,
Thanks for the help but I was well past that stage. After cleaning half a dozen times, changing beans three or four times, soldering the contacts on the switch, changing it, replacing the whole doser flap sled and anything else I could think to do I finally fixed it. It took me months but in the end it was the doser trap door not allowing the dozer flap to move back and hit the switch when the grounds came down. A simple light bending out fixed it. So...we had a rare mechanical issue. The machine does have a design flaw in that it has a long three inch shoot for the grounds which makes it susceptible to clogs. Do not use oily beans!
Posted on May 09, 2008
  • 833 Answers
The problem is that beans have particles and oil on/in them, jamming the switch which is giving you this message. Invert the unit on a hard surface covered with newspaper and give it a couple of strong taps against that surface. The junk should fall out and get you going again. Clearly, you're missing something when disassembling the unit.
Grinder does not stop
I need more information to solve this.
If you mean the grinder just spins but doesn't seem to be grinding anything - and then after 30 seconds or so it tells you the bean hopper is empty - then the problem is sticky, oily beans that aren't sliding down into the grinder.
You want to buy freshly roasted (roasted less than a week ago) beans. Coffee beans from the supermarket are old, stale and sticky with rancid oil. Even Starbucks and Peets - although the sign says "roasted daily" if you read the fine print, the beans in the store are rotated out 90 days after roasting. The oils turn rancid and get sticky after a couple of weeks so you really need to get beans from a local roaster or order them from a roaster who ships them fresh.
I have been using RedBird espresso blend and these beans work perfectly with this machine. They also are the best tasting of any espresso blend I've ever tried. The price is reasonable (cheap even) and the roast date is written on the bag. I get my beans 2 days after they were roasted.
http://redbirdcoffee.com/redbirdespresso.html
In the meantime, until you get some coffee beans that are not oily, you can stir the beans in the hopper. Use a wooden coffee stirring stick or a chopstick and just lift the hopper lid and stir the beans so they slide down into the grinder. You will probably have to do this before each coffee and maybe even 2-3 times just to get one coffee.
Once you get some fresh roasted beans that don't have that oily shine to them you will be grinding without any problems.
Oct 22, 2010 | Gaggia Titanium Espresso Machine
Brand new machine. coffee beans are loaded. when trying to make coffee the machine says the beans are empty. thanks
This machine doesn't like oily beans. Your best bet is to buy freshly roasted beans that are roasted to a FC or FC+. Viena, French and Italian roast beans won't work well. Also any beans that you buy at the grocery store will be quite old (often 3 months past roasting date) and they tend to be very oily on the outside.
If you have a coffee stirring stick or a chopstick, lift the cover of the bean hopper and stir the beans and sort of poke them down in the center - that's where the beans stick and can't drop down into the grinding burrs.
If you use oily beans you will need to stir every time or every other time you make a cup. Fresh roasted beans at a slightly lighter roast will work fine.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
Grinders do not always work and seem as if they are worn
The titanium doesn't like oily beans. Best results with fresh roasted beans that don't have an oily shine to them.
The workaround when beans won't go through the grinder - have a wooden coffee stirring stick (or a chopstick etc) and stir the beans in the hopper so they get down into the grinder.
Sep 27, 2010 | Gaggia Titanium Espresso Machine
Ground coffee will not dispense
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
May 29, 2010 | Gaggia Titanium Espresso Machine
Coffee beans empty but not
Could Be one of 2 things, the grind is set too fine and the beans are not getting to the millstones, or there is something blocking the chute for the grounds.
Dec 31, 2009 | Gaggia Titanium Espresso Machine
Gaggia titanium coffee beans empty
Hi
If the big knob in the bean hopper is on a small #, that could be your problem. try opening the knob to the largest # and try again. If it clears and makes a cup, then on the next cup, while the grinder is operating turn the knob down again, but to a larger # than you had before. Grounds can get compacted in the chamber and prevent new grounds from entering. That is why it grinds but doesn't make a coffee. If that doesn't help, try opening the door above the brew unit funnel when the brew units is out. It should pull down on a hinge. This is the clicking you hear when you make a coffee.
Oct 20, 2009 | Gaggia Titanium Espresso Machine
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Gaggia Trevi or Spidem Trevi
You may have a legitimate mechanical malfunciton but sometimes the simple solution is the right one! The chute on this (and other) superautomatic does not like the oily residue that beans inevitably leave. All it takes it gently putting one or two fingers into the bean hopper as the grinder motor starts to sound louder/faster (this is caused by the grinder motor being under less load/strain because no beans are feeding) and wiggling for 1-2 seconds. If you do this immediately after hearing the grinder motor's rpms increase you will not get a "fill bean hopper" error message2.gif. No hard pushing is required, just a gentle wiggle. There is a shroud over the actual bottom of the hopper, so you don't want to stick your fingers beyond that. If you are concerned about actually sticking your fingers into the hopper while the grinder is running, you can simply push down on the top of the beans with gentle pressure which will in effect force the beans down and accomplish the same thing. This technique + regular cleaning of the grinder may be all you need. Hope this helps! Tony
Jan 02, 2008 | Spidem Trevi Anthracite Espresso Machine
Gaggia Titaminu
check to make sure the blades are secured to the motor shaft. some have a set screw, some are positioned over a pin in the motor shaft.
Sep 10, 2007 | Gaggia Titanium Espresso Machine
Grinder spins but won't grind coffee
You have fill a water in your coffee grin
Jun 19, 2007 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
269 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
