Question about Tyan Thunder K8W S2885 Motherboard
I have a 1997 Subaru Legacy Outback Wagon and im having a problem with it overheating. I changed the thermostat 3 times...replaced the radiator...and still overheats. I took the thermostat out of car and ran it and it did not get hot but cant get heat in the car that way...Going Crazy trying to figure the problem out....ANY SUGGESTIONS
  • Kenny_Erika Feb 04, 2010
    I will def check that tomorrow. everyone keeps saying it could be the head gasket but if that was the case would the car still get hot even without the thermostat in it?
  • 617 Answers
Sounds like a bad water pump, if have thermostat out allready, remove cap start engine look inside rev engine see water move rapidly if not water pump bad, sure is problem
Posted on Feb 04, 2010
  • tim mcgrath Feb 04, 2010
    if was head gasket, start engine with radiator cap off, if shoots up out of radiator, yes blown head gasket but doesnt shound like you have that problem
1997 Subaru Outback Overheating, 129,000 miles
it sounds like the thermostat is sticking and i agree with the mechanic that that should cure the problem.If you still have plenty of fluid in the radiator that rules out a leak and if you had the timing belt replaced then the mechanic should have done the water pump along with the timing belt.So that leaves only one thing and that is the thermostat.
Dec 28, 2012 | 1997 Subaru Outback
How to bleed a subaru outback cooling system
Sounds like the thermostat is NOT functioning, since when its removed you can (apparently) fill the system. So ... replace the thermostat.
Bleed the system as follows:
1. Fill the radiator. Put on the cap, then squeeze the top hose 6 times. You'll likely hear some coolant gurgling.
2. Remove the cap, top up again.
3. Start the engine and let it idle. In about 5 minutes or less, the thermostat will open and the coolant level will lower. Turn off the engine. Go to Step #1.
4. You likely need to do this 2 or 3 times, till the gurgling stops, and you are done.
Nov 05, 2017 | 1997 Subaru Legacy
I have a 97 Subaru Outback which has developed a overheating problem. Did a thermostat late last year, and have just replaced it with a genuine Subaru thermostat and casing and still getting overheating...
If you had to bleed the radiator, it is likely your head gasket is allowing exhaust gasses into the coolant. A symptom of this is the coolant reservoir may seem like it is filling up. The other item which is simple and cheap to replace is the radiator cap. If it is leaking, it will allow too much fluid and pressure out of the system and then the coolant will boil. If it is the head gasket, the repair is expensive, usually $700 or more.
Feb 21, 2011 | 1997 Subaru Outback
I HAVE A 1998 LEGACY OUTBACK NO SMOKE NO SWEET
have you got heat in the car,what im saying is when you turn on the heater inside the car what happens?im not getting your drift,but get the thermostat checked out sounds like its not letting the coolant flow.adrian,,,,
Jul 21, 2010 | 1998 Subaru Legacy
I have a 1997 Subaru Legacy Outback Wagon and im having a problem with it overheating. I changed the thermostat 3 times...replaced the radiator...and still overheats. I took the thermostat out of car and...
Subaru's boxer engines have a known problem of blowing headgaskets, especially in the 90's (I have a 98 Impreza RS myself and have had mine blow.
Check to see if your oil looks milky? or bubbly at all. Or if there is exhaust dust or or oil in your coolant reservoir. If you have either one of those problems, you probably need to replace your headgaskets.
You should also check out your radiator fans. Notice if they both come on after the car is running for a while. They BOTH should after the engine gets hot. Drive it a couple miles, stop and check. If both fans don't come on, check the fan relays and also make sure you plugged in both connectors on the bottom of the radiator.
Feb 04, 2010 | 1997 Subaru Outback
2002 subaru legacy
Im wondering are your fans strong enough to cool down that aluminum radiator.
Aug 15, 2009 | 1991 Subaru Legacy
1997 subaru outback legacy overheating
I hate to tell you this but the guy isn't returning your calls because the head gasket is blown and he probably knew it.
As for the 1990... have you checked the water pump for leaks? (front/ driver's side on the bottom of the engine) My guess is that it's faulty and unfortunately, it's behind the timing belt.
Both of these repairs will be a pretty penny.
Jan 05, 2009 | 1990 Subaru Legacy
Overheat on my 1997 Subaru Legacy GT
Sorry if this might break your heart. I have '98 Outback which is the same 1st generation DOHC 2.5 engine. These are common head gasket problem (I'd say 100% of every engine sooner or later) once you have had your car overheated.
You will not get this comfirmed by just have your mech check the compression on the cylinder because we call it phantom leak (internal leak which can be confirmed with hydrocarbon in coolant). And then you will end up replace every other thing before you could reach the source of problem.
Other signs of this issue are as following: random overheating after freeway or uphills drive, bubbles in coolant overflow tank, oil residue in coolant overflow tank, bubble nioses from the a/c vent.
You're looking at $1000-1500 repair by independent mech as they have to pull engine out to fix the problem. I had mine fixed two weeks ago and now my baby is running like a champ.
google for "Subaru head gasket problem"
Dec 21, 2008 | 1997 Subaru Legacy
Thermostat Replacement for a Subaru
I have a 95 Legacy Wagon and by the shop manual the therostat sets on the bottom of the water pump. It is accessed from the bottom of engine by 2 bolts that hold the lower hose on.
May 30, 2008 | 1995 Subaru Legacy
Tyan Thunder K8W S2885 Motherboard Logo
94 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Larry Chandler
Andrew Taylor
Andrew Taylor
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
