Question about Ovens
Whirlpool wall oven error code
Our whirlpool wall oven gives an error code of F 03 and will not function.
  • Anonymous Mar 28, 2014
    Whirlpool wall oven electrical smell
    Electrical stink whirlpool wall oven
    President:
  • 2,651 Answers
F3 generally relates to faulty oven sensor. thin rod in upper left hand corner of oven cavity held in by 2 screwa, easy enough to replace,
Posted on Feb 23, 2008
Whirlpool electric double wall oven error code E2F6
Good Morning!
An E6-F2 is a very common control board failure. The control board in your appliance will need to be repaired or replaced.
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Mar 22, 2017 | Whirlpool Ovens
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
WHIRLPOOL OVEN SENSOR TEMPER for AKZ223 IX 858522304000
Aug 06, 2014 | Whirlpool Ovens
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
Hi my whirpool oven is stating F 03 what do i have to do? Thanks
Usually the F-03 error code means you have a bad oven tempreture sensor. To test the tempreture sensor you would use a multimeter set to ohms. At room tempreture the sensor should read between 1000-1100 ohms any less then this and you would replace the oven tempreture sensor in the unit. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s I also looked afterwards in your service manual and the F-03 error code does refer to the oven tempreture sensor
Sep 13, 2011 | Whirlpool RBS275PD Electric Single Oven
WHIRLPOOL AKR 301 IS FLASHING O3 F Fault code
F-03 code indicates a failure with the temperature sensor. The sensor comes into the oven cavity on the back wall and is a little smaller than a pencil.
The most common reason for this error is a wire connection between the sensor and the control board. Try to measure the sensor with ohm meter, an read about 1080 ohms at room temperature if it is good.
Hope this helps.
Jul 20, 2011 | Whirlpool AKZ159IX Oven
My 16 month old whirlpool inegrated oven has a fault code F03 on screen. How can i fix this myself?
The F 03 code indicates a failure with the temperature sensor.
The sensor comes into the oven cavity on the back wall and is a little smaller than a pencil. The most common reason for this error is a wire connection between the sensor and the control board.
You can measure the sensor if you have access to a good ohm meter. It should read about 1080 ohms at room temperature if it is good.
Aug 01, 2010 | Ovens
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
Ovens Logo
1,114 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
