Question about HP LaserJet 1300 Printer
Hi i have printing problem when i was gave print after output on print right hand side in some lines in black form contiuos print on paper.
  • fahadchippa Feb 04, 2010
    hi i have printing problem when i was gave print after output on print right hand side in some lines in black form contiuos print on paper.
  • 304 Answers
This problem occurs when the the cartrigdge drum was runout. By replacing the cartridge drum you will get good prints.
Posted on Feb 04, 2010
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
My brother gave me hos psc 1315 he had.The printer wasn't workin 1 year and i tried now to work and it doesn't print! The black ink is new (it prints 1 time when it wants not so clearly and then...
the printing cartridge are probably dry out. you can try to take them out and touch bottom side with soft paper to see if any ink will leak out. you can try to shake them rapidly while holding in hand, keeping the paper on the bottom side (because if theres ink you will get dirty :)
Sep 18, 2011 | HP PSC 1315 All-In-One InkJet Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Smearing toner on print surface - leaves black lines
dell 1700 printer prints black smudges on right hand side of paper only, about 3 inches apart?
May 25, 2010 | Dell 1700n Laser Printer
Paper wrinkles on one side when comes out of printer
Jan 31, 2010 | HP LaserJet 1300 Printer
Sharp Electric Cash Register XE-A203. I just put a new paper roll into the register because it was out of paper. The register screen is showing all numbers and transactions but when the paper comes...
Hi whitwall,
Please make sure that you have the right paper roll.
Your machine takes a thermal paper roll, which means it actually burns the print into the surface of the paper as opposed to printing with a ribbon or ink roller like other makes.
The thermal paper will only show a print on one side of the paper, in other words if you do indeed have the right roll and it is in upside down you will get a blank printout.
An easy way to see if it is the right paper hold the roll in your one hand and scratch a line with the thumb nail of your other hand accross the surface of the roll,if you get a black line on the paper then it is the right one, otherwise you have what we call a "bond" paper roll and it will not work in your machine.
If you got the "black line" with your thumb nail, then lift the printer head arm (green lever) place the roll in position with the paper rolling out from the bottom of the roll towards the front of the machine, pull the paper out past the catch mechanism and close the printer ****.Tear off the excess paper and replace the printer cover.
You should be ready to go ahead with sales.
This should solve the problem .
Regards
Gavin.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Black Line on Rt side of every printed sheet!
I don't know if this will help but I was getting smears on the right side of the paper where there was no printing. I came acrossed this and it worked for me. Open up the front cover and lift the top cover and remove the drum cartridge. Then with cartridge out remove the left and right screw on the side of the cartridge. This will give the drum belt room without hitting the cartridge case. The cartridges plastic was not formed well.
Skip
Jul 11, 2008 | Dell 3100cn Laser Printer
Vertical line down right hand side
crop toy jpg or bmp file from that side and then try I faced smae type of problem that process helped me you also try.
Mar 18, 2008 | HP LaserJet 1012 Printer
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
HP LaserJet 1300 Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
