Question about Samsung Digimax S500 Digital Camera
When you turn it on it aperars some parts white and some black
  • yolandap1 Feb 04, 2010
    my camera is a samsung s630
  • 10,515 Answers
When you Play the Movie / Image in the Playback Mode / Recorded Mode, do you able to View them properly or is that the same Problem.
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 04, 2010
  • taran_2005
    taran_2005 Feb 04, 2010
    Thanks for your response!!
    OK!! Try to play back the Saved Video's or look for Saved images ? Are you able to View them properly.
    If you are using Memory Card, then Pull out and see,if improve the situation?
    Hope i helped you.
    Thanks
Had the tail light assmbly (drivers side) on my 2006 chrysler t&c stolen. Took the plug too. I got the repair parts but cannot figure out the wiring. Four wires. Black with green stripe white with...
Not sure I follow your question. The replacement lamp assembly did not come with the wiring for the lights ?
According to the diagram, white lite green is the backup lamp, black dark green is ground, white brown is the parking light, and white dark green is the turn signal or brake light.
Jul 13, 2013 | Cars & Trucks
An error aperar wen i launch de my h03 apear un error says Error fan 01 and then turn off de projector,
maybe the fan for cooling the projector has a problem, you can bring it to the service center coz its not easy to replace those fan, thanks
Aug 07, 2011 | Computers & Internet
We purchased the Hunter Ceiling fan over a year ago and it has worked fine up until a couple of weeks ago. When we turn on the light it just continuously blinks on and off.
there is a watt governor, or black box for the lights to cut down on wattage or energy use. you can remove the black box for the lighting, and wire it directly to the main wires. white wire to white wire, and black wire to red wire. black and red are always a hot wire and white is a neutral wire. the part number on black box should be 98480-02. this should stop the lights from blinking. have a good day !
May 28, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
Desk top not along bottom properly icons all bunched up in a corner
right click on the start bar and make sure the 'Lock the Taskbar' option is not ticked (click on it if it is) . Afer that just drag the bar that aperars near the icons to the right:).
Oct 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Turns on but eventually freezes in black and white
is better if u replace the optical block cost less money , also it come with new lamp and color wheel and new ballast , all this parts go bad after couple years
May 06, 2009 | Televison & Video
Toner bottle does not turn to add toner
is the toner the Correct toner. If it is wrong the bottle will not Mesh with the motor
Apr 01, 2009 | Panasonic FP-7750 Black and White Copier
Wii cd rom will not work after i installed the wiikey2 chip. i tested the solder points and aperar to be no shorts to othe chips. The wikey chip turns on with red led power light, and then blue led turns...
temp solution, was to leave all wires solderd in place to confirm that there were no shorts , and to remove the Wiikey2 chip. The chipset on the wii is D2E.
I may have a bad chip or the wiring diagram is wrong....
I'll keep you posted when full modification is done.
Nov 13, 2008 | Nintendo Wii Console
Won't Turn On
Mine was a simple fix. Hope yours is too.
You need to take the unit apart to get to the cord reel. If you don't know how to take your unit apart, here are some instructions on how to take apart most of the Miele canister units.
http://www.sannerud.com/house/miele.html
Once it is apart, you will need to take out the cord reel. There is a small rubber hose which needs to be removed on the outermost part of the reel. Then there is one small silver screw that you must remove as well. One these two items have been removed, carefully lift the entire cord reel assembly upwards. When you are doing this, ensure that you are also lifting the black and white wiring along with the reel - just make sure that you're not yanking it and possibly breaking the connectors off. As you lift the entire reel assembly out, you can also remove the white wiring harness which connects to the main switches on the vacuum.
Now, here is the trickiest part - not really that tricky if you are good with your hands.
First, make sure that the cord is retracted fully. Then, start pulling the white plastic cord reel away from the black plastic assembly about 1 inch or so. Between the black assembly and the white reel, you'll notice a copper-like metal spring which is attached to the white reel. Make sure that as you are removing the white reel further, that you are maintaining visibility with the copper-like spring. DO NOT LET THE SPRING OUT OF ITS OWN WHITE REEL (the spring has its own reel which is difficult to wind up again, so be very careful!).
Make sure that the spring is fully retracted at this time. If it is not, wind the reel so that the spring is not wound up anymore around the white reel. Carefully slip the spring out of the white reel and leave the spring as-is ensuring that it does not unwind itself out of its own reel.
Now that you have the white reel off the black assembly, inspect the inside of the inner part of the white reel. You'll see two copper rings with 'wings' on them. These wings transfer power to the vacuum. There may be some grease (black) which you should wipe off with a paper towel. Also wipe the metal rings on the black assembly which touch these 'wings'. (the wings touch the metal rings to send constant power to the motor. The wings are there so that as you wind and unwind the power cord from the vacuum, there is always constant contact with the metal rings on the black assembly.
Now, carefully pull the wings up and out. If you can picture it in your head, what you're doing is ensuring that there is a good contact between the copper wings and the metal rings on the black assembly. Do this for all 4 wings on both the inner and outer copper rings within the white reel. Make sure that the 4 pads are clean and grease/dirt free.
Once you've done this, it's time to put the white reel back on the black assembly. Do everything you did earlier, but in reverse.
Carefully take the copper spring and align it to the white reel - you'll see a specific slot where the spring slides and grabs onto on the white reel. You'll probably have to place the white reel slightly onto the black assembly rod in order to achieve this - again, you must be good with your hands to do this without breaking anything.
Once the copper spring is attached to the white reel, press the rest of the white reel onto the black assembly. HINT: turn the white reel slightly so that you're applying some tension on the spring - this will make sure that the spring doesn't fall out of the white reel.
Reassemble the cord reel assembly (black and white parts) back into the vacuum. Make sure that the black and white power cables are out of the way. Once seated, wrap the black and white cables around the assembly and reseat the white wiring harness. Reapply the black rubber tube to the cord reel assembly and replace the silver screw to hold the entire harness down.
Close the vacuum casing, replace the control panel (power and cord buttons). Close the unit, plug it in, and power it on!
If it worked for you, congrats! If it didn't, sorry, you've got a much bigger problem with your unit.
Dec 23, 2007 | Miele S514 Solaris Turbo Plus Vacuum
Samsung Digimax S500 Digital Camera Logo
21 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
