Gateway notebook m-6309 keeps shutting down on its own while plugged into the charger.
  • 3 more comments
  • nu22day768 Feb 05, 2010
    Able to restart computer, but it keeps turning off while still connected to the charger.
    The computer takes anywhere from several minutes to several hours to shut down.
    Feb 05, 2010 - Able to restart computer, but it keeps turning off while still connected to the charger and battery.
    Feb 05, 2010 - The computer takes anywhere from several minutes to several hours to shut down.
    See less
  • nu22day768 Feb 06, 2010
    How does one go about getting the jack souldered or replaced?
  • nu22day768 Feb 07, 2010
    Thanks this was very happy.
  • 590 Answers
This may happen due to incorrect settings provided in the control panel -> power options.
open Control Panel -> power options -> change plan settings -> change advanced settings.
There find some options to restore your notebook power plan settings to default and click that button. This may vary between operating systems. I am attaching the image which describes about that in windows 7
I hope this helps you to solve the issue.
Thanks
Posted on Feb 07, 2010
    Novelist:
  • 153 Answers
You can try the following steps:
- Unplug the power cord from the laptop and remove the battery then press the power button of the laptop for 15 seconds
- Put the battery back in, turn on the laptop without plugging the power cord to the laptop then with the power cord (If this didn't resolve the issue)
- Remove the battery and press the power button of the laptop for 15 seconds, after that, plug the power cord and turn on the laptop (if this didn't resolve the issue)
- Turn off your laptop then drain the remaining power by pressing the power button of the laptop for 15 seconds. Open your laptop and reseat the CMOS battery.
- Remove the power cord and press the power button of the laptop for 15 seconds, disconnect the Hard drive and turn on the laptop (If this didn't resolve the issue) reconnec the hard drive
- Remove the Optical Drive and turn on the laptop (If this didn't resolve the issue) reconnect the optical drive
- Remove the memory chip, if you have 2 memory chips installed in the 2 memory slots (remove both of them) now test each one of the memory to each slots turning on the laptop. (If this didn't resolve the issue) Put the memory chip back in
- Reseat the CPU and try to make sure that it's installed properly. Turn on the laptop and test if it's gonna work (If this didn't resolve the issue)
- Reseat the power cords coming from the power supply of the laptop and test the laptop. (If this didn't resolve the issue)
- Disconnect everything and just leave the CPU installed and turn on the laptop.
- If all else fails, there's a big possibility that the problem may be with the power supply or the motherboard of the laptop.
(Note: Try to clean it properly if there is a large amount of dust in the laptop)
Regards,
sl4x
(If it resolved the issue, please vote for my solution)
Posted on Feb 06, 2010
    President:
  • 3,278 Answers
Hello.
The most common reasons are the power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is faulty and needs replacement.
Hope this helps.
Posted on Feb 05, 2010
  • NinaE Feb 07, 2010
    Thanks for using FixYa.
  • 4,889 Answers
Do you mean this does not happen when running from battery? Howlong does it take approximately to shut down once you have started it?
Please answer these questions so that we can continue with the diagnosis.
Sai.
  • 542 Answers
Check and let me know that, whether you can booting the notebook with battery mode. If yes, then there is a problem with power unit of your notebook. Need to repair the same with the help of local expert engineers or Service center experts.
Revert back for more assistance.
Posted on Feb 04, 2010
  • Rajesh Pai
    Rajesh Pai Feb 05, 2010
    As I told earlier, need to check your notebook with local expert engineers or Service center experts.
    Revert back for more assistance. Also please provide your valuable feedback/rating on the same.
  • Rajesh Pai
    Rajesh Pai Feb 07, 2010
    Please provide your valuable feedback and rating on the same.
Charger light goes out when plug in computer
it could be that the connection jack on the mainboard has been dislodged from the solder joint, common among Gateway comuters and HP units too. is the DC jack loose from the notebook ? if so thats the issue it seems. You will have to bring it to a computer person to resolder. if not and youc an do it yourslef, save money -- but be careful not to damage anything on the mainboard.
Jan 03, 2012 | Gateway NV5207u Notebook
My NV52 lap top computer shut down on me the other night and now i can't get it to power on. The charger works fine but when i plug it into the computer the light for the charger turns off.
remove the battery and try to power on the computer using just the charger. if you can try to use a different charger. if the charger light still goes off when plugging it in your computer then it might mean that there is a short in your motherboard. you can try removing the peripherals (i.e. memory, harddrive, DVD or CD drive, wireless card, battery or modem) to check if it is one of the peripherals causing the short. if you have removed all the peripherals and the system still doesnt turn on or if the power light on the charger still turns off and you have tried the charger on a different computer then it would mean the motherboard is damaged.
Apr 01, 2011 | Gateway NV5215u Notebook
Unexpectedly shut down, wont restart, bought a new charger, still no luck.Heeeelp
plug charger up keep pushingf2 repeatedley tell you the first page start up then change boot formate to f12 then when asked push f12 3rd time restart push f12 then staRT UP WINDOWDS SECOUND OPTCION.
Feb 15, 2011 | HP Compaq nx9030 Notebook
My battery light notifies my the battery is low so I plug in to the AC power and it still shuts off.
How long between plugging in and shut down? Many times what happens is it has already initiated the shut down sequence before you plug it in.
To prevent this, keep an eye on the power meter (put it in the systray if not already there) and proactively plug in the AC before it warns you. e.g. if it warns you at 10% when you see it reach 15% plug it in.
Mar 24, 2010 | Gateway 3520GZ PC Notebook
No power to my gateway m-6750 lap top. Have been
First use the following steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
If everything remain same, check the charger with a multimeter and match the voltage output with its specs.
If the charger is good, then there can be some problem with the DC jack (where you connect the charger).
Thanks
Feb 25, 2010 | Gateway M-6750 Notebook
My laptop was fine last night. i always use it on the charger but needed to take it off and use it. i did so and it ran out of battery so i put it on the charger but then it shut down. i just thought ill...
Remove the battery and mains adaptor. Press and hold the power button for a few seconds. Replace the battery and plug in the mains supply, press power for a few seconds and it should start up.
Aug 31, 2017 | Acer Gateway NV5814u Notebook
Gateway MT6451 Notebook won't boot.
try adjusting the screen lighting....
Sep 14, 2009 | Gateway MT6451 Notebook
Laptop shutting off
go to control panel and click on to power options. in that you can check whether you have accidentally set the notebook to shutdown after 10 min. thanks for contacting fixya!.
May 31, 2009 | Gateway 7320GZ Notebook
Laptop shutting off
There might be a setting in the BIOS that shuts down the computer when the processor gets too hot. so, getting better cooling or turning off the setting will stop it. but, if you disable the setting, the Processor could overheat and explode.
Jun 11, 2008 | Gateway 7320GZ Notebook
63 people viewed this question
k24674
jasbo
jasbo
